Can this work with genuine AVDI pass thru?
How is the VAG EDC17 working? I haven't seen many responses
I have a lot of problems with Amarok.
Write mod error. does not work.
sum = ok
sun ols = ok
Ktag on the bench ok.
MMCFALSHERfor cars UDS
med17 edc17 uds w/mod ecu car has 1 ECU injection
med17edc17 stock w/ori ecu car has 1 ECU injection
med17 edc17 slave w/mod ecu2 slave ( car has 2 ECU injection a master another slave).
med17 edc17 slave w/ori ecu 2 slave (car has 2 ECU injection a master another slave).,
lately i do not have errors.
Hi thank for you
Thank you i am
Thank you iam
PCM Flash is the Best for MED17 EDC17 VAG ecu
Redline Tuners
Automotive Tuning
What do I need to read/write with MMC Flasher an MED17.2 Ford?
- Chipsoft J2534 Mid & K-line (https://ecutools.eu/chip-tuning/adap...-chipsoft-mid/)
- MMC Flasher (https://ecutools.eu/chip-tuning/mmc-flasher/)
- 27 Module, Ford Bosch MED17.2 (Identification, map area reading/writing, error reading/deleting, checksum correction, virtual reading, VBF into BIN conversion.)
Is that all ?
you cant use vas5054A as pass-thru J2534 device ?
After trying to write mod file obd2 MMCflasher Amarok , error edc17c54, loss of communication.
Ecu does not communicate.
using pcmflah does not password you.
eeprom normal reading. eep can read and write
flash error password.
Is there any way to recover?
30/01 :The mistake was mine, a tool works.
what type of speed for reading / writing of the nissan ecu via k-line is to be expected? right now it takes around 3 hours for a full read using nisread software via k-line..
How to obd read fuso canter edc16 or edc17
is this good for vag Simos pcr2.1? Skoda superb with cayc engine code?
Yes, suitable for PCR2.1 ECUs
BR
Professional EGR, DPF, CAT, VSA, NOx, ADBlue, DTC solutions here...
Hi everyone, I need a clarification, I would like to buy the official MMC Flasher software with module 69, I would like to buy it to work on the DENSO Gen2 ecu. My doubt concerns the tool, can the software work with openport 2.0 clone or do I have to buy an official tool? What do you advise me?
Thanks in advance
