Page 8 of 11 FirstFirst ... 34567891011 LastLast
Results 106 to 120 of 161
  1. #106
    Oct 2015
    Quote Originally Posted by gonzagnr View Post
    does the nexiq usb link interface work with this software?? is j2534 compatible.
    regards.
    i been using it with nexiq 2 no issues
  2. #107
    I have good luck with ford sid208. Bruce great with support. Excellent Product.
  3. #108
    UK
    MMC FLASHER WITH VAG EDC17/MED17 MODULE....
    HAS ANYONE USED THIS ON EDC17C46
    MK6 GOLF 2.0 TDI
    I HAVE USED IT...ID ECU AND OBTAINED THE ORIGINAL FILE FROM THE SERVER...FLASHED THE ECU ALL OK.
    NOW THE ENGINE IS IN BAD LIMP MODE..20MPH MAX...AND NO CODES STORED AT ALL IN THE ECU.
    FILE RECIEVED FROM SERVER WAS---FL_03L906018--9970
    HAS ANYONE USED THIS FILE.
    MAGPRO X17--AT-200--SCANMATIC BENCH--PCMFLASH--MITSUBISHI MUT-III---OPENPORT 2 MMC FLASHER
  4. #109
    What did you find?
  5. #110
    anybody can help me. My supporter is missing.
    I try mmc flasher in passat B6 3C but without success.
    can you help me where is problem?
    car info: passat B6
    Address 01: Engine Labels: 03L-906-022-CBA.clb
    Control Module Part Number: 03L 906 022 MS HW: 03L 907 309 B
    Component and/or Version: R4 2,0L EDC G000SG 4080
    Software Coding: 0000071
    Work Shop Code: WSC 80093 222 71269
    VCID: 020FCF015D909651FF-8056
    Thank you.
    br
    gsmpuky
  6. #111
    UK
    I have had the same error codes on a audi 2010 170bhp tdi...
    I did a diag on the car no problem.
    but tried to id the ecu with kess and no joy..
    also had the same with mmc...no id and the very same error codes...
    BUT..THIS CAR HAD ALREADY BEEN MAPPED...But it would be interesting to no the solution to this..
  7. #112
    UK
    Default just seen this immo off med17 edc17 module.
    http://ecutools.eu/additional-equipment/mdflasher/
    anyone on here using this module.??
  8. #113
    DK Veteran hercamp's Avatar
    Yes I used and its save my axx
    When need.
    .its really good
    Sent from my Lenovo K52e78 using Tapatalk
    the life is easy... people complicate!!!!!!!!
    life is funny just step away of people that wants make your life a shixx
    http://youtu.be/PEw3nYmpEys
  9. #114
    Aug 2015
    can read write all ecu toyota via can bus obd?
  10. #115
    italy
    Hello everyone.I have openport 2.0I want to buy MMC Flasher.do you know if there is anything in the modules between the modules with a motorcycle?I know the 25m module allows me to write kawasakiother?
    use thanks please
  11. #116
    EARTH
    mmc is UDS ... NOT any vag.
  12. #117
    italy
    [QUOTE = Zohar; 2957200] Cosa intendi con 'blank ecu'?
    Se si intende quella ECU come nuova nello stato di fabbrica - MMCFlasher consente di leggere / scrivere ECU senza problemi
    Se la connessione CAN con ECU non è possibile (nel caso in cui il bootloader in flash di MCU Renesas sia stato distrutto) solo Pisaini, Fgtech e strumenti simili possono scrivere flash in MCU (tramite connessione RX TX sul banco)
    BR [/ QUOTE]
    question:
    mmc flasher don't write renesas SH processor with RX and TX ?
    i interested to this fuction for renesas SH 7052-7054-7055-7058
    use thanks please
  13. #118
    Jun 2017
    I just flash a Nissan rogue 2016 sh72531 sucesfully ,unfortunately only read write maps and calibration not full read immo stills flashing.
  14. #119
    May 2016
    Russia
    Do not use MMCFLASHER for Nissan/Infiniti Hitachi SH705x SH7253x, there is no successful experience. After some time lights up CE, checksum error. The author promised to correct this.
  15. #120
    Please can I get pinout of Honda accord 2005 ecus with no. 37820-RAD-A54
