Page 1 of 2 12 LastLast
Results 1 to 15 of 23
Hybrid View
    Top Poster + trance's Avatar
    Aug 2009
    Default DM800SE Triple tuner setup
    Hi, people......
    Just installed a triple tuner into a dm800se. The sat side of things is working sweet, I dont have cable, so cant test that at the moment. However , how on earth do I setup the DVB/T side of things.I've read up online but they are all regarding DVB/C.
    Has anyone got the triple tuner working on all s/c/t. And how did you do it please.
    Mar 2010
    Hi mate
    I have a couple of sr4's, terrestrial doesn't work in the UK and obviously you need a cable feed to set the tuner up.
    There are two ways you can configure the tuner, you can either install the trial tuner driver and use oe1.6 images or
    you can use oe2 images but you will need to edit your cables.xml/satellitesxml and merge them together.
    You will also need to scan and create your own channel lists with merged xml files as the lamedb file is different.
    TBH they are a pain in the butt, but on the plus side if time is on your side your new acquisition will take plenty of it!
    There is plenty of info available and I will be able to help but you need the cable feed before you go any further.
    003
  3. The Following User Says Thank You to 00360362878 For This Useful Post:
    trance (20th December, 2014)
    Aug 2009
    Thanks for the info, I basically got the triple tuner as virmin will be rolling out my area soon .
    I thought in the mean time I would play around with the Dvb/t to see how it goes.
    But I had no idea it was a no go in the UK.
    003 , once I get the feed I will take up your offer of help....in the words of arnie "I'll be back" give or take a couple of months.
    Aug 2009
    003, true to my word, I'm back...
    Right I should have access to a live feed in the next few days or so...
    I'm currently running the latest openpli as my dm800se has an a8p sim.
    So if anyone can kindly advise me as to what I need to get the triple tuner working on cable, would be much appreciated.
    ( I don't mean lions softcams etc..as im clued up on that side of things as I'm not new to enigma2)
    Ive read, I may need lamedb cables.xml net id. Is it even possible with the latest openpli, just read on another forum[ post was from 18 months ago ] that newer oe 2.0 images dont work with the trial tuner driver, quam 256 fault???
  6. The Following User Says Thank You to trance For This Useful Post:
    00360362878 (5th April, 2015)
  7. #5
    Mar 2010
    hi trance, what is your area?
    If you are in the north west I will find it easier to help you. Trial tuner isn't needed with the image you are using, but the config is tricky with a
    modified satellites/cables.xml and correct tuner settings.
    I will message you!
  8. #6
    Aug 2009
    Quote Originally Posted by 00360362878 View Post
    I will message you!
    Sorry for the late response, I set up a duo2 last week. That was straight forward, I did not have enough time/ and know how to setup/test a trip tuner dm800se....But I've done some reading up on the subject, an hopefully I'll try it soon [ vm is not in my area at the min, so have to go around mates]
  9. #7
    Oct 2008
    I would be grateful for the same help as I have the same box and live in Batley West Yorkshire and have VM as my cable provider. The Sat side is working but cant suss out how to get cable going.Thanks
  10. #8
    Mar 2010
    Guys
    I will put together some files that will help you soon and I will upload here in a zip file.
    will include
    Tuner settings
    a working north west (modified sat/cable.xml) file. From this you should be able to work out how to edit your area .xml
    my working canel list. which is probably only good for north west.
    Once you have configured your sr4 you will need to perform a scan, it will scan sat and cable automatically.
    unless you are northwest, then you would use my files and be up and running in 30mins.
    003
  11. The Following User Says Thank You to 00360362878 For This Useful Post:
    trance (11th April, 2015)
  12. #9
    Oct 2008
    That would be great 003. Look forward to that
  13. #10
    Mar 2010
    Default sr4 help file
    Ok guy's here is a help file that will put you on the right track.
    If you are in the north west you are in luck! as everything you need is in the file, unfortunately if you
    are in a different area you will have to do some reading, but that's what it's all about.
    003
  14. The Following 3 Users Say Thank You to 00360362878 For This Useful Post:
    malutki21 (13th April, 2019), potel (24th April, 2020), trance (12th April, 2015)
  15. #11
    Feb 2015
    HI can you please explain where the zip files are to be placed in the dreambox with DCC
    thanks HT
  16. #12
    Apr 2019
    Working Great!
  17. #13
    Aug 2009
    Thanks 003, looks like I'll have to read up a wee bit, before I start editing the file...
  18. The Following User Says Thank You to trance For This Useful Post:
    00360362878 (13th April, 2015)
  19. #14
    Mar 2010
    Quote Originally Posted by trance View Post
    trance if your mate has a working cables.xml file working for your area, you need to take a copy and have a go at the edit.
    I use conText to edit all my files, google it, it is a free download.
  20. #15
    Aug 2009
    Hi, guys .....well well well, Ive been reading up on the matter in hand, and after a fair few edits etc . I cant get my sat.xml to be recognised/scanned.
    Everytime I try your one [003] that is recognised and scanned witout issue[ obviously wrong area to work for me] but when I try mine, either I cant get it to show in the tuner configuration....or when it does show up there, it stops scanning after the satellite is scanned/ cable wont scan...
    Where am I going so wrong?
    here is a little snippet of my edit ;
    </sat>
    <sat name="Simmys Cable" flags="1" position="1">
    <transponder frequency="05067500" symbol_rate="06952000" polarization="0" inversion="0" modulation="0" fec_inner="5"/>
    <transponder frequency="05070000" symbol_rate="06952000" polarization="0" inversion="0" modulation="0" fec_inner="5"/>
    <transponder frequency="05147500" symbol_rate="06952000" polarization="0" inversion="0" modulation="0" fec_inner="5"/>
    and towards the end it looks like the following;
    <transponder modulation="0" fec_inner="5" symbol_rate="06952000" inversion="0" frequency="01150000"/>
    <transponder modulation="0" fec_inner="5" symbol_rate="06952000" inversion="0" frequency="01230000"/>
    <transponder modulation="0" fec_inner="5" symbol_rate="06952000" inversion="0" frequency="01307500"/>
    <transponder modulation="0" fec_inner="5" symbol_rate="06952000" inversion="0" frequency="01310000"/>
    I have tried to follow your advice, and I look forward to some more, I'm not giving up just yet, oh no
