Results 1 to 15 of 20
    Feb 2014
    Slovakia
    Default W463 cluster dump virginize request
    I am searching for someone who can help me to edit my gauge cluster dump from MB W463 G-Class. I need to virginize it because cluster came from other car so I am not able to adopt it to my car (married in DAS Xentry). I tried to reset km to 0 but that doesn't work. There is still VIN from another car so the only way is to make it "virgin". Thank you in advance.
    W463 A2C53182572 VDO 24c16 origo.zip
    Rerouter's Avatar
    Jul 2014
    Australia
    This should be it, any chance you have the vin this dump belongs to, could mean i just change that next time,
    Feb 2014
    Slovakia
    thanks a lot sir, I am sorry but I don't understand exactly ... what did you mean with vin this dump? ... vin of my car is WDB4633231X131035 ... I though that if I make clusters as virgin I can adopt them, as they are new, to car with MB star diagnostic?
    Rerouter's Avatar
    Jul 2014
    Australia
    Sorry, to clarify i was hoping you might know the vin from the car this dump belongs to, at a guess it ends in 31061, or at-least is contained in this rather large string: "532893540000310611200719151821"
    worst case grab another dump when you recode it for your vin and i'll point him out for next time,
    Feb 2014
    Slovakia
    OK. Unfortunately I didn't know vin which is stored in cluster... I will try to flash it and I will see if works (marry with car) or it will still shows ODO " - - - - - - ". May be there is way to edit eeprom with ezs blocker... I will let you know.
    Thank you a lot.
    workshop
    odo have key id,you must odo learning to eis,after can you km see
    Feb 2014
    Slovakia
    I tried to delete km to zero but doesn't work, I tried to set same km to cluster and eis (ezs), doesn't worked. Its because cluster which I want to transplant to car is from newer model. Now I have merc W463 year 2002 and new cluster is from facelift model year 2007. I saw many car with this upgrade. Also merc c-classes. Everybody who done this upgrade talking about virginize cluster as they seems to be new. Diagnostic can't adapt cluster to the car with different vin code. Thank for any help or solution.
    workshop
    your eis 2002 year and cluster2007,one have old eis,(hc08)cluster 2007 have eis with hc912
    you can newer coding facelift cluster to old eis
    Feb 2014
    Slovakia
    if I can how to code it.
    Feb 2014
    Slovakia
    ok I understand...but is there some solution how to block cluster to read km from eis? I saw lot of pictures with this upgrades. Thanks.
    Feb 2014
    Slovakia
    I tried your dump, but doesn't work nor the gas gauge doesn't show fuel level
    workshop
    you can coding tank other level sensor
  13. #13
    Feb 2014
    Slovakia
    I bought cluster on eBay...tank sensor was already coded its ok...so you think there is no way how to show odo?
  14. #14
    Feb 2014
    Slovakia
    and what about some other things like menu items coding ( navi, tel, speedtronic, to show or hide) is there some dash algorithm to edit hex dump? thx
  15. #15
    workshop
    you can with star old or new levelsensor coding
