plz help just to make sure.
Results 1 to 7 of 7
    Jul 2014
    Default plz help just to make sure.
    i have done another syscheck for my wii 4.3u i need help to see if it will work now. here are the syscheck results plz help me.
    sysCheck v2.1.0b19 by Double_A and R2-D2199, Nano
    ...runs on IOS58 (rev 6176).
    Region: NTSC-U
    System Menu 4.3U (v513)
    Drive date: 2008.12.18
    Homebrew Channel 1.1.0 running on IOS58
    HomebrewFilter ist nicht installiert
    Hollywood v0x21
    Console ID: 202216727
    Boot2 v5
    Found 84 titles.
    Found 55 IOS on this console. 7 of them are stub.
    IOS3 (rev 65280): Stub
    IOS4 (rev 65280): Stub
    IOS9 (rev 1034): No Patches
    IOS10 (rev 768): Stub
    IOS11 (rev 256): Stub
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS16 (rev 512): Stub
    IOS17 (rev 1032): No Patches
    IOS20 (rev 256): Stub
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS30 (rev 16174): Trucha Bug, NAND Access
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 3608): No Patches
    IOS37 (rev 5663): No Patches
    IOS38 (rev 4124): No Patches
    IOS40 (rev 16174): Trucha Bug, NAND Access
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 16174): Trucha Bug, NAND Access
    IOS51 (rev 4864): Stub
    IOS52 (rev 16174): Trucha Bug, NAND Access
    IOS53 (rev 5663): No Patches
    IOS55 (rev 5663): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 16174): Trucha Bug, NAND Access
    IOS61 (rev 5662): No Patches
    IOS62 (rev 6430): No Patches
    IOS70 (rev 16174): Trucha Bug, NAND Access
    IOS80 (rev 16174): Trucha Bug, NAND Access
    IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
    IOS222[38] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS223[38+37] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS224[57] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
    IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
    IOS245[37] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS246[38] (rev 21008, Info: d2x-v8final): Trucha Bug, ES Identify, NAND Access
    IOS247[53] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS248[55] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS251[58] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v10
    Report generated on 2014/11/24.
    DK Veteran Keithuk's Avatar
    Aug 2010
    England
    Don't any games work of a USB drive?
    Well your previous sysCheck had more IOS's that were Stub 17 now you only have 7 so you didn't do everything I said in that post #4 did you.
    You need to install IOS11 and IOS20, if you want to remove IOS16 Stub install my cIOS16-v257
    Last edited by Keithuk; 31st October, 2015 at 01:53 PM. Reason: New location for cIOS16-v257
    Keith
    2010 Golf GTD (170)
    Jul 2014
    can you plz help me on installing IOS11 and IOS20. and how do i remove IOS16 with your cIOS16-v257. oh one more thing can you help me with installing usb loader because i cant seem to find anythin on how to install usb loader the correct way i have a wii 4.3u
    Aug 2010
    England
    If you extract cIOS16-v257.wad from that zip file and install it with Multi Mod Manager (MMM), along with IOS11v16174(IOS60v6174[FS-ES-NP-VP-DIP]).wad, IOS20v16174(IOS60v6174[FS-ES-NP-VP-DIP]).wad from ModMii.
    USB Loaders v3.0 is on here.
    Keith
    2010 Golf GTD (170)
    Jul 2014
    Here is my other recent syscheck. can you check to see if it is ok or anything else is needed.
    Region: NTSC-U
    Priiloader installed
    Hollywood v0x21
    Boot2 v5
    Found 84 titles.
    Found 55 IOS on this console. 6 of them are stub.
    IOS16 (rev 54321): Trucha Bug, ES Identify, Flash Access, NAND Access
    BC v6
    MIOS v10
    Report generated on 2015/09/30.
    Aug 2010
    England
    That doesn't look too bad you have a couple IOS11, IOS20 that the stubs need removing.
    Download ModMii6.3.1 and run ModMii.exe from Windows. Use the SU option from the main menu and find the location of the sysCheck.csv from the sysCheck which is on the root of the SD card. That will download all missing wads and apps to COPY_TO_SD sub folder. Copy IOS11v16174(IOS60v6174[FS-ES-NP-VP-DIP]).wad and IOS20v16174(IOS60v6174[FS-ES-NP-VP-DIP]).wad to the wad folder on the SD card.
    Put the SD card back in the Wii and run Homebrew. Run Multi Mod Manager (MMM) should be the first app listed select it and load it. Once running scroll down to WAD Manager and press 'A' that will default to all wads in the wad folder. If you want to install all wads shown just press 1 that will list all wads you want to install press 'A' again to install them all.
    Watch for the Installed OK message after each one. If any don't say that message make a note of the wad name and back out. Scroll down to the wad that didn't install and press the + button the put a green + next to it then press 'A' to see that wads name listed then press 'A' to install again.
    Keith
    2010 Golf GTD (170)
    Top Poster icepick's Avatar
    Apr 2008
    S.Ireland
    Hi wiihackplz, did you ver get sorted ?
    I don't visit this site much these days but in the past guys that took the time (like Keithuk & others ) were invaluable to my knowledge about the wii, & always friendly and patient )
    . . . if a posting helps . .it cost nothing to say a thankyou
