You must also swap flash memory and MPC content if its flashable. eeprom only is not enough because of EWS data in flash etc
Hello my friends..
Hope you all got a nice Christmas :-)
For me Christmas was good :-) yesterday only start working and i broke ecu with opening, verry stupid....
What are my options now?
I find second hand ecu on google with all the numbers the same wil it work when i solder the eeprom to the new ecu are wil nothing work and i need to buy new ecu bye dealer?
Hope somebody can give me a hand?
Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
Professional Engine Software Development
I can not read the old ecu with trasdata error.
Otherwise i try clone it with second hand ecu.
When i open it i hit a resistor and i repairt it with resistor from other ecu only still no contact with ecu :-(
So wil it work when i only solder the eeprom to new ecu? all the numbers are the same from second hand ecu, Are can somebody help me and give me virgin file so i can let bmw program the other ecu for me?
Are can i buy used one and someone can help me with pincode for key? are something like that?
This is first time bmw ecu broken so new for me :-)
Hello mate,
BMW cars don't have PIN code.
To program new DDE with dealer software (ISTA/P) you need virgin file for your ecu, but very hard to do...
If donor ecu has same numbers of original ecu you can solve by writing eeprom dump to your new ecu (flash is the same because same part number).
Mr. lupu_sandu is 100% right, ISN and ecu sync is in eeprom. In flash you will find only UIF VIN and nothing else.
UIF VIN (and VIN generally) is not mandatory to start the engine on BMW cars.
Bests
need same ecu number and swap eeprom.
ALL TUNING.
THE BEST OR NOTHING. THANKS + REPUTATION .
sazimam11 (13th January, 2017)
Thank you i will buy the used ecu.
Thank you i hope it wil work.
When i am ready i wil post it here if it worked.[
QUOTE=paskuale;2446779]No, different VIN in flash is not a problem and does not give you any DTC.
Car start without any problem with different vin in DDE flash.
In this ecu you will find 95640 eep.
Bests[/QUOTE]
Read the CAS and post eeprom/flash of the new ecu and I will make pairing for you.
DONT FORGET TO LEAVE THANKS + REP!!
DPF, EGR, O2/LAMBDA, ADBLUE, VMAX/SPEEDLIMIT, CHIPTUNING FOR PETROL/GASOLINE AND DIESEL VEHICLES!
EDC17 VAG IMMO OFF, ECU CLONING, BMW EDC17 ECU CLONING!!!
Please i'm looking for a original bdm backup of ecu 0281016639 1037500775 for repair a damaged ecu, someone can help me please?
Thank you in advance
