Audi A7 2011_repair DEF please
test repair
test repair
choro (29th December, 2014)
You not read good data is corupted
I had same issue using dp3 it's always better to back file using another programmer ie Xprog wrote original file all was okay
no work again DEF and km show --------
Hello. I have the same problem as you. Dp3 gave me the DEF box. Law with plug 1 eeprom I was put in DEF. I re-eeprom and everything is correct but only lasts a day. How can I return to that table the kilometers I had or how can I change them and make everything right? Thank you.
Digiprog 3 = dp3
Enviado desde mi SM-N9005 mediante Tapatalk
if you had done a search on here before doing the car youd see using this cheap tool results in you paying a small fortune to get this fixed , i hope you charged enouygh to cover the repair cost
buy a propper tool there not that expensive to do these cars and try reading before doing , would you jump out of a plain before learning how the parachute works ???
All about the Bass
lush29 (6th May, 2017)
I understand perfectly. But I do not look for more problems. I am looking for a solution In this alive to know more there that to fall much and to have support. That's what I like about you.
I think only solution for this is used cluster with component protection removed
Can CP be removed? I know you can copy cp did not know you can remove.?
Hello friends. Does anyone know if you can change the frame of an a7 with ref 4g8920930p for another scrapping or secondhand ?? If only it would have protection of components if it was removed everything would be fine, right? What kilometers would you have left? Thank you
you need someone with odis online to remove component protection and adapt new dash to the car.
then you will need to correct the mileage again ..
