93c86 inside and some others 93c66
morito (30th December, 2014)
hi
thanks but need secure info, the dash is expensive if broken
regads
It's not 93c86, maybe c66 but not sure..
If I helped you, you may use thanks and reputation button on my post. Thank you!
for for year I think is 93c66 but I need confirmation
i have done 2012 good while back was s66 normal size eeprom your dash looks the same , it was needles off for me..
i have the dump if you need,,
morito (31st December, 2014)
You have the dash ,, just open and look and u will find whats inside ,, if you have a good programmer all will be ok
Think it will 24c16,2kb in size,and rolling code.
Read it,bang the dump up here,and will be changed within 2 minutes !
i think is 93c66 for year and is denso dash
Toyota Allex - 93c46 Denso
Toyota Allion - 93c66 Yazaki
Toyota Alphard - 93c56 Yazaki
Toyota Altezza - 93c46 Yazaki
Toyota Altiz - 93c46 Denso
Toyota Aristo - 93c46 Denso
Toyota Aurion - 93c66 Yazaki
Toyota Auris - 24c16 VDO
Toyota Auris - 93c66 Denso - 2013 years
Toyota Auris - 93c86 VDO - 2007-2008 years
Toyota Avalon - 93c46 Denso - 1998 year
Toyota Avalon - 93c46 Yazaki
Toyota Avalon - 93c56 Denso - 2008-2009 years
Toyota Avensis - 93c46 Denso - 2004-2008 years
Toyota Avensis - 93c46 Yazaki
Toyota AURIS 2013:
yes the eeprom is in anoter face and is 93c66
I have 62697 and need 12000 km
many thans in the advance
sorry this is dump
Like that mate ?.........
Try amd report
many thanks
