USB loader GX "Exception (DSI) occurred!"?? From nowhere..
Results 1 to 4 of 4
    Dec 2012
    Default USB loader GX "Exception (DSI) occurred!"?? From nowhere..
    Hi guys, i have a problem with USB Loader GX.
    I cant open the program anymore, all it says is "Exception (DSI) occurred!"
    It's really strange because it worked like 1 hour ago, when i last turned it off and now all the sudden this shows up.
    What can the problem be?
    It always crashes after its preparing cIOS...
    Please help!
    Here is my Syscheck report:
    sysCheck v2.1.0b13 by Double_A and R2-D2199
    ...runs on IOS58 (rev 6176).
    Region: PAL
    System Menu 4.1E (v450)
    Priilaoder installed
    Homebrew Channel 1.0.0 running on IOS0
    Hollywood v0x21
    Console ID: 136175788
    Boot2 v4
    Found 108 titles.
    Found 52 IOS on this console. 8 of them are stub.
    IOS3 (rev 65280): Stub
    IOS4 (rev 65280): Stub
    IOS9 (rev 1034): No Patches
    IOS10 (rev 768): Stub
    IOS11 (rev 256): Stub
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS16 (rev 54321): Trucha Bug, ES Identify, Flash Access, NAND Access
    IOS17 (rev 1032): No Patches
    IOS20 (rev 256): Stub
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS30 (rev 54321): Trucha Bug
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 54321): Trucha Bug, ES Identify, NAND Access
    IOS37 (rev 5663): No Patches
    IOS38 (rev 4124): No Patches
    IOS40 (rev 3072): Stub
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 54321): Trucha Bug
    IOS51 (rev 4864): Stub
    IOS52 (rev 5888): Stub
    IOS53 (rev 5663): No Patches
    IOS55 (rev 5663): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 54321): Trucha Bug
    IOS61 (rev 5662): No Patches
    IOS62 (rev 6430): No Patches
    IOS70 (rev 54321): Trucha Bug
    IOS80 (rev 54321): Trucha Bug
    IOS202[60] (rev 65535, Info: hermes-v5.1): Trucha Bug, NAND Access, USB 2.0
    IOS222[38] (rev 65535, Info: hermes-v4.0): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS223[38] (rev 4, Info: hermes-v4.0): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS224[57] (rev 65535, Info: hermes-v5.1): Trucha Bug, NAND Access, USB 2.0
    IOS236 (rev 54321): Trucha Bug, ES Identify, NAND Access
    IOS247[37] (rev 21006, Info: d2x-v6): Trucha Bug, NAND Access, USB 2.0
    IOS248[56] (rev 21006, Info: d2x-v6): Trucha Bug, NAND Access, USB 2.0
    IOS249[57] (rev 20, Info: rev 20): Trucha Bug, NAND Access, USB 2.0
    IOS250[57] (rev 21006, Info: d2x-v6): Trucha Bug, NAND Access, USB 2.0
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v10
    Report generated on 2015/01/01.
    DK Veteran Keithuk's Avatar
    Aug 2010
    England
    This error has been talked about before http://www.digital-kaos.co.uk/forums...curred-313482/
    That's sysCheck isn't to bad you just need to install a few IOS's IOS11, IOS20, IOS40, download d2x v8 Final wad pack and put these in the wad folder on the SD card, install all 7 wads when you install the other wads.
    Download ModMii6.3.1 and run ModMii.exe from Windows. Use the SU option from the main menu and find the location of the sysCheck.csv from the sysCheck which is on the root of the SD card. That will download all missing wads and apps to COPY_TO_SD sub folder just add all files and folders to the SD card, then add all 7 wads from d2x-v8.
    Or you can extract the missing files from COPY_TO_SD
    Keith
    2010 Golf GTD (170)
    Dec 2012
    Quote Originally Posted by Keithuk View Post
    I've downloaded ModMii 6.3.1.
    However i don't know what to do next since there is 19 files to be downloaded. Should i install all of them?
    Here is a picture of what it looks like! View image: SU
    Should i uninstall anything or just install those 7 WADS that are inside the folder?
    EDIT: the problem is still there... It didnt work
    Aug 2010
    England
    Yes you need to install IOS11, IOS20, IOS30, IOS40, IOS50, IOS52, IOS60 and all 7 wads in d2x v8 Final wad pack
    Keith
    2010 Golf GTD (170)
