here you go this is from jc bsi 2009 flash again the attached flash file with FVDI. Make shure you have a good power supply charger connected JCI_BSI_.rar pas pm
Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
Je besoin de Flash pour citroen c4 picasso 2008
966405908001
BSI04EVK04-00211207
boot 28120836-4
dur 28119248-3B
v5.01
signature DC.04
vous et joyeux no?l merci
[QUOTE = doctore; 2918247] Ici, vous allez ceci est de jc bsi 2009 Flash ? nouveau le fichier flash attach? avec fVDI. Faire shure vous avez un bon chargeur d'alimentation connect? [attach] 417550 [/ attach] pas h [/ QUOTE]
Thank you, I will try, need the pass.
.....see inbox or empty first
tekn95 (25th December, 2016)
Thank you, I will try Monday
hello to all I'd need some help, I also blocked by BSI Fvdi in an attempt to read the pincode of a Citroen C4 Picasso 1.6 of 2009 with BSI number 9664058780 ... I include photos of the software release, with file read by fvdi before block and after the block .... more My problem is that now fvdi does not write to me giving me the original file checksum error with fvdi helpppp please ....
THE current problem is that not fvdi does not make me any more write flash and getting this error file
flash again the attached flash file with FVDI. Make shure you have a good power supply charger connected pas pmJCI_BSI.rar
filoxio77 (4th January, 2017)
DSC_0358.JPG .........write new bsi
You flash soft version from other source.
Morfej you the king use then file from morfej will work 100%
I also enable I-terminal that reads this is BSI flash EEPROM .... but the two files beds with fvdi and I-terminals have different format ...
