Page 1 of 21 12345611 ... LastLast
Results 1 to 15 of 306
    Nov 2011
    Default CITRO?NN PICASSO 2009 / BSI FLASH PROBLEM
    Citro?n Picasso 2009 with BSI and 95128 eeprom / Johnson Controls.
    DP3 has done writing the new km value by "flashing" by OBDII "reading, verifying, writing" but only until 99 %.
    Now car is "dead" , no functions anymore.
    Need to tell also that i forgot to put extra battery charger, so this was happen when voltage dropped and now car is "dead"
    Re-write with DP3 is possible apparently, recognise BSI number (but NOT the VIN) and does automatically pick-up the saved
    "flash-file" and will try to recover, BUT DP3 dont flash anymore when arrived @ 99%....
    EEprom data looks oke, but i have no idea how to solve this problem !
    Put all FF in eeprom also dont wake up the car
    Any clues or suggestions ?
    Thanks in advance
    DK Veteran sl4ck's Avatar
    flash BSI with FVDI or SMOK PSA tool, give reference number on label
    96xxxxxxxx
    BSI 20xx xxx- xxxxxxxx
    BOOT xxxxxxxx
    HARD xxxxxxxx
    xxxxxxxxxx
    KTAG, PCMFlash, Galetto FGTech V54, Smok Multitiool UHDS, I/O Terminal, Fiat/Alfa IAW Bosch Decoder, UPA-USB, XPROG, FVDI, Orange5, Renolink, DiagBox, Can Clip, Xentry
  3. The Following 2 Users Say Thank You to sl4ck For This Useful Post:
    boris93600 (2nd May, 2018), pouettedu76 (22nd January, 2017)
    Nov 2011
    i do not have SMOK or FVDI
    PSA = 96 640 590 8002
    V 05.01
    281201930C
    N805243015
    boot 28120836-4
    hard 28119248-3 C
    BSI 04 EV K04 - 00 020309
  5. The Following User Says Thank You to CARPARTS For This Useful Post:
  6. #4
    May 2012
    Here is your eep file. If from a C5 2.0 hdi 2009.
    966405908002
    bsi04ev k04-00 -81209
    b28120836-4
    hw 281192483c
    v05.01
    281201930c
    read1 bsi m95128.rar
  7. The Following 3 Users Say Thank You to tziku For This Useful Post:
    A630V (19th August, 2018), boris93600 (2nd May, 2018), willyboy28 (15th February, 2021)
  8. #5
    He needs flash i think, if eeprom data is ok, flash is messed up.
    Don?t know if you can do anything with easyCAN4, it has jtag interface, but don?t really know if it is solution to flash over jtag.
    http://www.scaleochip.com/images/Pdf...32-BRF-200.pdf
  9. The Following 2 Users Say Thank You to sl4ck For This Useful Post:
    boris93600 (2nd May, 2018), CARPARTS (4th January, 2015)
  10. #6
    hello
    i have a same probleme whit the same car !!
    i have repair by obd whit UHDS psa
    have you the backup of the flash?you can repair by obd
    regard
  11. The Following User Says Thank You to newgeniehex For This Useful Post:
  12. #7
    Nov 2011
    Hi, here is the saved data from DP-3 / 992 kbyte (flash)
    You need eeprom too ? (manual readout by removing eeprom)
    You clearly see the area's where are '00' instead of data, comparing other fkashes from DP3....
  13. The Following 5 Users Say Thank You to CARPARTS For This Useful Post:
    Barajasz207 (22nd October, 2019), boris93600 (2nd May, 2018), canisha (31st October, 2017), sep382 (3rd August, 2020), willyboy28 (15th February, 2021)
  14. #8
    hello
    now you can use this backup but you must to use uhds tool psa
    no need backupt of eeprom
    after you have restore the bsi the car start direct!!!
    can you put the sw of the bsi can you make a picture of the reference of the bsi please
    regard
  15. The Following 2 Users Say Thank You to newgeniehex For This Useful Post:
  16. #9
    Nov 2011
    mmm, oke, but i dont have uhds tool
    will bring car to PSA dealer and maybe online re-flash will work ??
  17. The Following User Says Thank You to CARPARTS For This Useful Post:
  18. #10
    hello
    psa dealer can not do repair by obd,sorry
    have you try again to restore by obd to DP3
    try to contact the support
    regard
  19. The Following User Says Thank You to newgeniehex For This Useful Post:
  20. #11
    Nov 2011
    Yes, i did try again
    1/ DP3 does recognise only some parameters like HW version, and VIN, but VIN : "...." is not visible, although the VIN is cleary in 3 positions in eeprom.
    2 DP3 ask new km
    3/ DP3 start asking "ignition off & on", then wtart to write back this saved file, but arrived at 99%, stops writing and thats it..
    Support on Sunday is difficult, will ask tomorrow morning.
  21. The Following User Says Thank You to CARPARTS For This Useful Post:
  22. #12
    Nov 2011
    Other question ; IF i could find second-hand BSI, which number(s) on BSI-label should be the same as the original BSI-number(s) ???
  23. The Following User Says Thank You to CARPARTS For This Useful Post:
  24. #13
    hello
    now i don' t have my dp3
    in the menu bsi you don't have option write or restore the bsi?
    regard
  25. The Following User Says Thank You to newgeniehex For This Useful Post:
  26. #14
    Your flash is corrupted.
    Here you are good one (software signature 67.8A):
    JCI_BSI_678A.rar
    WBR, Marek
  27. The Following 19 Users Say Thank You to tech_cz For This Useful Post:
    A630V (19th August, 2018), boris93600 (2nd May, 2018), BusCan (30th October, 2019), garagecfa (30th January, 2020), garageozcar (24th April, 2018), gogoli (21st June, 2018), karri (23rd February, 2019), kronk92 (10th February, 2019), kumbari (6th December, 2017), mecafrigo (27th June, 2017), Neodim60 (9th March, 2023), pautri (13th November, 2017), pepe111 (15th December, 2017), pinokio383 (22nd October, 2017), pouettedu76 (22nd January, 2017), prodlt (2nd September, 2018), RomanDon (22nd August, 2018), wojtech (7th March, 2024)
  28. #15
    Nov 2011
    Well, after all i managed to "repair" it as follow :
    The flash dump as attached above "BSI_JC_FLASH_M00" is as i told before ; full of area's with "00", so its corrupted in my opinion.
    Tech-cz also mentioned this.
    Each time DP3 will try to restore, also as commanded in the log-file, the original flash.
    But for some reason DP3 take all time the "BSI_JC_FLASH_M00" and stops at 99%.
    In the MCC card/storage there is some other 992 kbyte flash with name "BSI_JC_FLASH_01" which is the +/- SAME as the attached flash from tech-cz.
    This flash is the real original flash, and the "...M00" is the modified flash.
    Now the trick is : change the name from the "01" flash into "M00" and the "M00" into "01".
    Then DP3 will AGAIN try restore the flash with of course "M00", but this time the content is the good one because i "misleaded" DP3 by changing file-names
    And indeed, this time until 100%, car start and you only need to re-do the whole procedure "read, verify, write" BUT THIS TIME WITH AN EXTRA BATTERY CHARGER .
    Hope this will help some members with the same problem.
  29. The Following 26 Users Say Thank You to CARPARTS For This Useful Post:
    A630V (19th August, 2018), Aliazadar (14th March, 2018), boris93600 (2nd May, 2018), BusCan (30th October, 2019), clauberty (15th March, 2015), Faraday (29th March, 2015), gabrielandriev (16th September, 2018), gogoli (21st July, 2022), jackeldestripador (14th November, 2017), javiere (27th November, 2017), javyb (5th January, 2015), junmab (5th January, 2017), kelekele (15th March, 2015), kronk92 (6th February, 2017), lion0304 (20th April, 2015), makadam (8th December, 2019), MERCO86 (5th January, 2015), Prestigeauto (6th May, 2018), Recoder (16th March, 2015), sendreq (22nd November, 2016), Speedofix (16th March, 2015), taxo1965 (12th October, 2017), tor2lehel (8th July, 2015), tziku (5th January, 2015), urcarpc (13th January, 2015), xifly18 (2nd April, 2018)
