Page 42 of 45 FirstFirst ... 32373839404142434445 LastLast
Results 616 to 630 of 661
  1. #616
    Nov 2008
    5 Miles North Of The Toon
    I have tried every fix that I have found on the net, Its ok on my local network, But still cant get it to stream over the net, Why is it so difficult to get this working.
    Think I will give up
  2. #617
    Feb 2011
    @manhatten
    i to was thinking the same but it dos work i was test streaming to my brother overseas was a bit jerky but was not bad.
    i had tried to use this before but did not get anywhere, installed again but had more problems installing and trying to open it!
    so i reformatted my pc, which was about time anyway.
    i did the following
    pli-jade max var image on dm500s
    vlc-0.9.9-win32 on pc
    updated my no-ip dns
    port forward port 1234 to my pc
    port forward port 5678 to my pc
    installed Tunisiasat_dreambox_player_and_webstreamer_6.1.0 on pc
    then i just hit Start Streaming, i can then see thhe link
    mms://mydns.org:1234
    i just gave this to my brother and he opened url with media player.
  3. #618
    Nov 2008
    Thanks for the info simbad16, I may have another try to get it working, But if you look at the number of views 94,211 There is not many saying that they have it working.
  4. #619
    Feb 2011
    silly questions
    is your domain updated to your current IP?
    did you select start restreaming, traffic light should turn from green to red. sometimes i have to start-stop and start again. then it starts streaming
    another thing i notice cpu usage goes up too 100% so i make a point to close all other programs
  5. #620
    Nov 2008
    Thanks again simbad16, I am now looking at getting a Slingbox
  6. #621
    I have 6.1.0 working on my DM800 with the New Dream Elite image. I see that when it is streaming to the web, the red light flashes and all the other channels are greyed except for channels on the same transponder so I cannot change a channel with the remote controller. Sometimes this continues even after closing the streaming program and the DM800 thinks it is still recording so I have to reboot. It's not a problem but I'm wondering if anyone else sees this or whether it is just my setup that's causing it.
  7. #622
    Nov 2010
    I have been trying to get this working with no success (on my home network).
    On the DM800 web interface, the WebTV does not work. If I click the icon beside a channel for 'TV' then I get the download m2u file which I can open in VLC.
    The stream opens in VLC and after a while will end (sometimes only a few seconds and other times a few minutes)
    When I run this program, it never shows any picture. I just get the VLC icon and I am able to see the channel listings.
    If I hit re-stream then it shows me the URLs momentarily and then stops!
    Any ideas????
  8. #623
    Apr 2011
    can this work vise versa where i can stream pc to dreambox u may have to use vlc frontend plugin on dreambox
  9. #624
    Feb 2011
    i have now since changed my dm500 with vu+ solo i just changed dreambox model from 500 to 800 and all is still working fine.
  10. #625
    Aug 2011
    I cant get the Test connection of Dreambox ?
  11. #626
    The Stig PT mtv1's Avatar
    Apr 2008
    Tipperary
    using dcc ??
  12. #627
    Aug 2011
    I want to see and control my Dreambox from my nete cafe by using the TS dreambox player !
    But the test connection not connected ?
  13. #628
    Aug 2011
    Update my question !
  14. #629
    Nov 2008
    fahi
    you need to be specific
    do you in pc ts palyer you got no connection with dreambox
    if this this the case in settings checl dreambox ip is correct,is the pc and dreambox connected to same network,is there firewall block the dreambox ip,is the webinterface is enabled and active
    note the dreambox webinterface in many clone images is not working and you need to fix
    try to dreambox ip in internet explorere what you get?
  15. #630
    Aug 2011
    Hello mfaraj57
    Dream-box IP is correct and i checked it.
    The dream-box IP works fine in Firefox browser !
    No , dream-box and PC are in deffrient network.
    Firewall is Off.
    Locally TS player works fine with PC and get connect when both are in the same connection !
