Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
  1. #16
    Top Poster + damiensk's Avatar
    manchester
    thanks for your help vorlon,
    have now updated to what i believe is the latest version january 2015, 0a07oa00_1.6.54 emu.
    couldnt see anything about a loader version on the site?
    another thing is all my sly bouquets have now gone, do you know where i can d/l a file?
    thanks again
  2. #17
    DK Veteran vorlon2257's Avatar
    Sep 2011
    Vorlon Homeworld
    No mate can't help you there, only thing I can think off is to do a search on google to see if there are any on there.
  3. #18
    manchester
    thanks anyway. will do a search
  4. #19
    DK Veteran mini's Avatar
    Apr 2008
    W Yorkshire
    I also have issue with the Amiko mini combo, unable to get past the password.
    what firmware do i need as well as the upgrade tool. Also is it a 3.55mm (3 pole)jack needed?
    I prefer dreamboxes, this is a favour for a friend.
    All help is much appreciated, thank you
  5. #20
    Apr 2008
    W Yorkshire
    Managed to sort it. Got loader from amiko and firmware from amiko website.
    then as I didn't have a rs232 to 3.5mm cable, I had to solder the wires direct on to the female jack on the board and it worked.
    If anyone has to do same then the wires to solder are: the tip is TX then Ground, RX and then ground.
    If anyone needs to make or order a cable then you will need rs232 and a 3.5mm (4 pole) jack.
  6. The Following User Says Thank You to mini For This Useful Post:
    jovie (6th August, 2016)
  7. #21
    Mar 2017
    hi
    PLZ CAN SOMEONE HELP ME OUT
    I HAVE AMIKO HD 8150.....
    1] I NEED A SOFTWARE TO UPGRADE BY USB
    2]CONDITIONAL ACCESS I CAN GET IN NET CLIENT CONFIG EACH TIME I TRY ITS ASKING FOR IN PUT PASSWORD --------
    PLZ HELP ME THIS IS NEW TO ME
    THANKS
  8. #22
    P&D's Avatar
    Everything you need is here.....http://amikoreceiver.com/amiko-hd8150/
    P.s........turn your caps off........
  9. #23
    Mar 2017
    Thankyou
    Sorry to trouble you but don't know what link to download. ....
    Can you tell me which link do I downloaded and would that remove the password from net Client config.
    Thanks☺
