Immo OFF, not possible!
buy new remote control and align, EWS with ECU, as in BMW !!
..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
not need new remote or keys, only realign dde-sawdoc, must have proper tools, forget bmw tools, if not have tools read ecu eprom and pic from sawdoc and put dumps here, if cannot read pic from sawdoc because is locked, buy ews from freelander (see pic), read dump from motorola,make transponder, and put here for manual sync
It is posible to use immo emulator like this ?? https://carlabimmo.com/bmw-emulator-immo/
bleah, emulator ........... , and where is beauty of our job ?
ps. think yes, work with emulator
Hi All please i need some help to sync a set for the same vehicle. have the exact same problem. attached are ecu and immo dumps, if possible can i have the isn no?
mahmood44 (24th July, 2018)
hola me podr?a ayudar con la sincronizaci?n ya que el intercambio est? echando a perder y es uno de desguace y necesidad de sincronizar
English senior
hello I could help me with synchronization since the exchange is spoiling and is one of scrapping and need to synchronize
Hi Folks,
elephantu, can you help with manual sync of this landrover?
Thank you in advance
of course, put this in ecu
Immo off is now possible for this ecu by 8soic eeprom.
I want this solution from frozen land ...
Best regards.
Dragon
Unforunaly not starting
