Page 15 of 48 FirstFirst ... 5101112131415161718192025 ... LastLast
Results 211 to 225 of 720
  1. #211
    igorr's Avatar
    Aug 2010
    problem with tag programmer
    its stop to read 4d and 4c and id46 transponders,I can't find solution
    tray to resolder evrything but same,maybe someone have solution
  2. #212
    gopelhu's Avatar
    EU
    Quote Originally Posted by igorr View Post
    Hi Friend,
    It is no problem, bec the tagkey tool has read only 4bytes these chips.
    I also get this showmessage: Transponder can't read !!!
    FVDI cannot read some chipid all infos but only 4bytes. It is no problem.
    Pls use the tango programmer and/or VVDI prog programmer.
    The VVDI prog programmer is VERY GOOD programmer, I recommended you.
    Regards, G
  3. The Following User Says Thank You to gopelhu For This Useful Post:
    igorr (9th January, 2016)
  4. #213
    lidons's Avatar
    Feb 2011
    I correct @olpehu. VVDI-por is a programmer, you mean VVDI2.
    excuse my English, is the best.
  5. The Following User Says Thank You to lidons For This Useful Post:
    gopelhu (8th January, 2016)
  6. #214
    Nov 2015
    Hello everyone!!! I have this version of FVDI pcb, reading the whole thread I managed to understand that is the clone of the clode, as you can see it does not have the DS2460. The problem with it is that it does not work on edc15, so I guess is a k-line issue, My question is, do I have any chance of ever making it work better or the solutions apply only to the fly company hardware. Or is there any possibility to find another(better) interface and have it wirking with the software (all 18 active) that I allready have. Thank you!!!20160107_230721.jpg20160107_230753.jpg20160107_230955_003.jpg
  7. #215
    gopelhu's Avatar
    EU
    Hi all,
    Here is common user guide for ORIG AVDI.
    It is the latest... including passtru drivers installations....
    Regards, G
  8. The Following 14 Users Say Thank You to gopelhu For This Useful Post:
    carcode (23rd July, 2018), carsoftobd (27th January, 2016), Col19 (5th October, 2022), fliper (27th March, 2017), Gery (16th January, 2016), HAMIZA (17th July, 2018), irco (7th March, 2017), ker0sin (14th April, 2016), keyantic (5th August, 2019), killian2008 (19th November, 2018), pattaya2001 (17th September, 2016), ultim4te (13th May, 2017), yahia1908 (30th September, 2017)
  9. #216
    autocargo's Avatar
    Quote Originally Posted by stefyhgs View Post
    This may help you:
    change this two chips: L9637D and ADG1406BRUZ
    If K-Line still not work, try to replace K6 Omron 61g1 MOS relay with an original working one.
    It has been discussed on this forum...
  10. The Following 2 Users Say Thank You to autocargo For This Useful Post:
    Col19 (8th December, 2020), gopelhu (14th January, 2016)
  11. #217
    Member madmen's Avatar
    Jun 2009
    hello menbers need info about my fvdi
    I was noticing that missing two components, I wanted to ask which components are? See image
    They need or not need to put them?
    then the other question, I have difficulty with reading EPROM with fiat commander V.54, with error, time out reading, especially with Marelli 6JF, Marelli 6F3, k-line and can, there is a possibility to solve the problem?
    My fvdi and 18 all activated software, my best regards
  12. #218
    gopelhu's Avatar
    EU
    Quote Originally Posted by madmen View Post
    Your interface a clone of clone, not a FLY company product !!!
    The two IC that are the missing : DS2460 SO8 and 74HC32 SO14, but these ics are does not need !!!! All FVDI works perfectly without these IC's.
    Try to read all ecus with this sw version: Fiat v5.1. I tried several times all Fiat ecus and works perfetly with ECU flasher and ECU cloner... etc.
    Regards, G
  13. The Following 3 Users Say Thank You to gopelhu For This Useful Post:
    Col19 (8th December, 2020), madmen (15th January, 2016), mickye_dj (13th April, 2016)
  14. #219
    Jun 2009
    Quote Originally Posted by gopelhu View Post
    Regards, G
    hello thx to reply me,in effect version v5.1 work , marelli j6F read 2Ep ,write 2 ep, but not write nothing,because i read again 2ep and same old buffer, iaw 4Af read and write perfect same for marelli 59f clone ecu work perfect, marelli ME7.3H4 boot mode work perfect,only version v5.4 same ecu not work, but version v5.1 ok,marelli body computer punto with code read perfect mcu,panda body computer same perfect V5.1 and ypsilon body,tacho, ecu ME7.3H4 ok
    maybe is the version v5.4 have a problem
    i found internet version v5.7 but can work with my interface? there is a risk to block my fvdi with this version?
    my best regards
  15. #220
    gopelhu's Avatar
    EU
    my best regards
    Hi madmen,
    I tried some fiat ecus the v5.1 version and works perfectly.
    The newest version ( v5.4 ) has some bugs and maybe this is your problem.
    Pls do not try the v5.7 version bec it is an online version, and if you does not have a softdog version then the v5.7 will be damaged your FVDI.
    Regards, G
  16. The Following User Says Thank You to gopelhu For This Useful Post:
    madmen (16th January, 2016)
  17. #221
    Out side world
    Hello friend, I have a 2015 FVDI softdog (Full 18 sw) expired.
    I've tried to do many things and I managed to change the days of activation available.
    I managed to change the playing softdog.
    the program starts but fails to connect with FVDI. waiting to connect to interface .......
    anyone know how to link the tool?
    greetings from the Mediterranean
  18. #222
    gopelhu's Avatar
    EU
    Quote Originally Posted by franke232 View Post
    Hi, pls write me a pm
  19. #223
    Jan 2016
    This picture of botom side, from what version is?FVDI ver 3 and 4 not have bottom components.
    All components marked and on internet you can find their usage.
    ADG1406BRUZ-16 channel multiplexer ,etc...
  20. #224
    Out side world
    Quote Originally Posted by ahmed3 View Post
    Versi?n 6.3 SW
    versi?n pcb Flyaudi V4-1
    firm 1 versi?n 2.18
    firm 2 versi?n 2.10
    unit buy in flyobd
  21. #225
    gopelhu's Avatar
    EU
    Versi?n 6.3 SW
    firm 1 versi?n 2.18
    firm 2 versi?n 2.10
    unit buy in flyobd
    Hi mate
    You have a big problem, You made a mistake !!! Warranty lost your FVDI, bec you removed the battery from softdog.
    WTF.... OMG......!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!
    Regards, G
