mickye_dj (1st September, 2018)
When i use vag 18 with programmer in the same time ... program get error and close (program do not responding)
do you know what is the problem ?
thank you in advance
i did and its the same problem....
i restart computer and its same problem - with v21 not have this problem .
but i need to use VAG v18 sometime ...
i install to another computer and its the same ... tested in XP and WIN7 32 bits
Thanks you in advance
I've got fvdi clone of clone i have problem it suddenly stoped working when i connect it on BMW i opened it and the AU5790D ic was burned now when i connect to PC nothing it is completly dead please i need nelp.
Thanks in advance..
What help do you need with? You need to replace damadged component mate first.
Does any previous cracked version work?
And another questions from new user of FVDI, (clone of clone, i guess.Seller told me: "plastic case version, better made than paper box one") Should it somehow read micronas cdc32xx from instrument cluster?
Because i am dissapointed. First i tried to add keys to 2010 Audi A3- no success. Engine 1,6 CR TDI (not programmable it claims), cluster with eeprom and micronas. I said to myself: "oh well, equipment is cloned piece of crap, and car is relative new". Then, i tried to read pin from my own Xsara Picasso Bsi,(older version) again no success. I said: "well, maybe it's time to buy newer car, this one is too old for my FVDI"
But when it fails also add key to Skoda Roomster (dash same as old Fabia and Ibiza, no dealer key needed, EDC15 1,4 tdi "hand compactor" engine) i was seriously pissed off.
The only good thing was: diagnostic worked well, and FVDI gave me login from cluster, but i had to use VCDS to add key. (I suspect the adaptation channel was different from deafult, because VCDS has two channels to Add keys, one worked, another not.) I could do it faster by open EDC, read 24c04 and use my GENUINE VCDS which never dissapointed me.
Oh, and the antenna doesn't recognize any chips. Programmer is recognized, led's blinking but that's all. Btw antenna cable looks like cable from cheapest chinese speaker set.I'm affraid it'll crack, when it will be cold.
ps. Any idea what resistance antenna should have?
Hi mates,
I've got a 2015 fvdi with softdog, the softdog seems to be poorly made.
The battery solder has lost its connection, I reconnected it.
Now it tells me my serial is 0 , i tried to flash it using fwdownloader, but it doesn't work. I dont either know if those firmware were mine, it was just in my Files folder.
My FVDI was a VAG one with id F06580
Is there a way to save my FVDI? Or at least flash it to work like those "18 software fvdi" all around?
Right now it is giving me "Error 4" and on my normal software with online activation "device has closed".
Those are my current files I have flashed : https://mega.nz/#!Gw4GiIAS!JH5ZH5SLUcwz3m-dWTbXB7Mwm3wIL5H9izMMA6ZSLWg
Thank you mates!
forgot... sorry
Here is your F06580 FVDI fwdownloader with files ( but your tab.dat file is a missing)
Regards,G
Hello, who can give me the reference of the component with the red arrow on the image?
mage?
Please help me
Hi guys, i have fvdi that not working via can protocole, detecting only gearbox via k line, what could be problem? software v21 vag, thanks
