Hello everyone,
I buy fvdi 2014 at fly gary, it made bad backup of the flash of the bsi of my c4 picasso 2008, several byte a ff, is it a software or hardware problem? excuse me for my English
Hello everyone,
It is a pcb version flyaudi-v4.1
I want to bay abrites full 18 software mode china , it's work good ???!
worth every penny
Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
Hi all again,
Somebody can tell me what capacity these condensators from FVDI?
C9,C13,C14,C29,C49, top side
C46,C47 button side
Many thanks, G
Hello, I do test on table with other bsi JC evo the same problem.
Bonjour, pouvez-vous me dire ce que je devrais utiliser l'application?
I used the original fly verdun v 6.0.0.1
Envoy? de mon D6503 en utilisant Tapatalk
I used the original delivered by fly v6.0.0.1
Hello guys,
I have a FVDI interface and it has problems when I try to use it with K-line. For example, when I try to use even the diagnostic function on the instrument cluster of a VW Golf Mk4 1.4 16V the interface connects to the cluster but after 5-6 seconds it looses connection. On CAN it works perfect. I have change the L9637D and the ADG1406BRUZ but stiil no result for the K-line problem.
My question is: if I use Micromax's solution will all the interface's function work? Or should I first try and change the ADG1404YRUZ to see if it works?
AGDiag (14th January, 2017)
