Page 23 of 48 FirstFirst ... 13181920212223242526272833 ... LastLast
Results 331 to 345 of 720
  1. #331
    gopelhu's Avatar
    EU
    Hi all,
    I have a big question .
    Somebody have the setup file with Qickloader v6.1?
    If so, pls share it.
    Thank you, G
  2. #332
    Mar 2016
    RO
    @gopelhu I've tried your solution but it's still the same problem. I loose connection after a few seconds
  3. #333
    gopelhu's Avatar
    EU
    Quote Originally Posted by AGDiag View Post
    This is BOO RB dashboard, golf IV. Its maybe the jubileum version and i have one solution.
    This dashboard rolling seed code version and if the fvdi cannot setting the seedkey then this dashboard will be close.
    pls remove from the car and pls try again in desk.
    If you need the connection pls write me a pm.
    Regards, G
  4. #334
    Mar 2016
    RO
    Ok. The next days when I have some time I will try this. But the problem is the same with EDC15.
  5. #335
    Hi friends,
    I have FVDI full with 18 softwares and I got "power surge on hub port" error when I plug it in, can anyone help me with this ?
  6. #336
    Aug 2015
    Quote Originally Posted by hornhunter View Post
    Hi friends,
    Did you try other PC? usually that would be computer problem
  7. The Following User Says Thank You to dtip For This Useful Post:
    gopelhu (17th January, 2017)
  8. #337
    Quote Originally Posted by dtip View Post
    I tried on several pc's, same thing...
  9. #338
    gopelhu's Avatar
    EU
    Maybe the USB connector is a A version but you need the B version.
    Can you share the pcb picture top + button side?
    Regards, G
  10. #339
    Sep 2016
    Hello everyone....fvdi is my clone,clone clone....no working k-line,first replace all OMRON relays,no working,next desolder adgbruz1406 and gADG1404BRUZ 2 piece, doing like micromax picture no working.I order new ADG1406BRUZ and L9637D and waiting .Qickloader v6.3 .Maybe you know the problem? change new adg1406bruz and L9637D and no working?thanks for answer
    P_20160919_133052.jpgP_20170207_132342.jpgP_20170207_132408.jpgP_20160919_144611.jpgP_20160919_144625.jpg
  11. #340
    Sep 2016
    next be problem,when connect bmw e60 damage, fvdi (AU5790 Single wire CAN transceiver) why? thanks for answer
  12. #341
    can i user ori avdi to fvdi soft?
  13. #342
    Sep 2016
    fvdi soft Qickloader v6.3
  14. #343
    barteczekk's Avatar
    Jan 2014
    someone can tell me where to buy good clone of this tool ? and what is the difference between this AVDI FVDI SVDI its a lot of them. (i know its nooby questions but no one knows all)
  15. #344
    Aug 2015
    Quote Originally Posted by barteczekk View Post
    There is literally thousands of posts all around internet about fvdi fly, fvdi fly clone, avdi original, svdi....what they work what does not, prices, manuals , fixes, rework..... just use google and it is best way to figure out yourself, it is not that complicated if you are in this bussines...just use search, read , compare prices...etc...
  16. #345
    barteczekk's Avatar
    Jan 2014
    i know that. but i tough someone got tested source.
