Page 26 of 48 FirstFirst ... 16212223242526272829303136 ... LastLast
Results 376 to 390 of 720
  1. #376
    gopelhu's Avatar
    EU
    Quote Originally Posted by kartas View Post
    my fvdi clone clone no serial number.no flashing or lighting.when connect fvdi usb and pc usb is ,no drivers nothing?thanksAttachment 459010Attachment 459011
    write me a pm
    Regards,
  2. #377
    I am thinking of buying a fvdi from aliexpress, can anyone recommend a certain model and if any mods are required what are they?
  3. #378
    shafo's Avatar
    Apr 2016
    Sa
    Quote Originally Posted by servicekey View Post
    hello friends, My genuine AVDI don't communicate with CAN protocole, It's work great with K line, tag tool work fine too, but CAN no, any help please?
    thanks.
    Hello friends...my avdi is doing exactly this..i opened up interface and see 1 adg1404 slightly brown...when i connect avdi to obd that adg1404 gets VERY hot ..no warantee on my interface..do you guys think it's worth it to maybe replace that one component?
    Please add rep if I help you
  4. #379
    shafo's Avatar
    Apr 2016
    Sa
    Quote Originally Posted by shafo View Post
  5. #380
    hello to all
    hi GOPELHU thank you for sharing i have an avdi id A01002 not work
    can you help me how to reflash it
    thanks in advance
    best regards
  6. #381
    Junior Member andrewsh's Avatar
    Feb 2017
    Hello. I buy fvdi rev4.1
    can work. k-line not work.
    change 2pcs ADG1404YRU, ADG1406BRUZ and l963d - not work k-line
    what can I do to repair it?
  7. #382
    turbocip's Avatar
    bad post
    was deleted
  8. #383
    gopelhu's Avatar
    EU
    What is the problem with your fvdi?
    Led flashing red or green or....????????????????????????
    Is your fvdi chipid:
    0A0C0707570957532C13314F040000F5
    And calibrated:
    Benz,Toyota,Hyundai,TagKeyTool,
    If so, then pls write me a pm.
    Regards, G
    Quote Originally Posted by abdelamjid View Post
    hello to all
    thanks in advance
    best regards
  9. #384
    gopelhu's Avatar
    EU
    Pls replace also the ADG1204YRUZ ic
    Regards, G
    Quote Originally Posted by andrewsh View Post
  10. #385
    gopelhu's Avatar
    EU
    Pls replace are the following parts: ADG1404YRUZ and TJA1050 and if it has an ADG1204YRUZ then pls replace also it.
    Regards, G
  11. #386
    The exchange hw does not help.Bad crack sw.
    Not signal input for IO
    Data goes but nonsensical
  12. #387
    Hello everyone, could you find out in any way the value of the diodes D6, D8, D2 and D3? the diode that has black stripe I think it is a general purpose diode and those that have blue stripe are zener diodes, but is there any way to know the value of the diodes?
    Thanks in advance
  13. #388
    hello
    sıkayp zeki19-06@hotmail.com
  14. #389
    Jan 2016
    which PCB version is better ?
    this one ???
    or this one ?
  15. #390
    Hi all,i have FVDI Flyobd 2014.I tried to diagnose(diagnostic function) skoda octavia Ii k line.aAll units found.The unit central adres 35) was not found?Vag Com OK
    And special features have gone K ine.
