mrchip (26th November, 2017)
Thanks for answer
I read also on other forums that version 2014 is better then 2015,,
can somebody share an link for 2014 stable version ? does matter with or without online functions?? ( I mean which one is more stable )
what is the difference between softdog and dongle ? both looks same
I need calculate long code of vw airbag cars... Avdi clone can make this? I hear about vcds can make,but only online... Anyone know about?
Enviado de meu SM-G920I usando Tapatalk
Hello friends. Will anyone repair FVDI 2015 (CHINA) ??? After connecting the USB there is no reaction ... the FVDI does not turn on the led ...
Hello. Is this fvdi from fly ? I tried today to remove seat mat from a BMW E90 and could not do it. Not from the button, and not from coding. When I want to read coding it sais that it could not read coding or wrong chassis selected. Tried with 1 series, 3 series...
Stelaras26 (29th December, 2017)
Thank you for the reply. I have tried again and it worked. Strange that it would not work in the first time.
gopelhu (28th December, 2017)
Hi Gopelhu, i wrecked my fvdi with reading a Toyota avensis with 4A-FE engine. Pin 9 got the full load of high voltage from the dlc connector of the car and now the fvdi is dead. i replaced the lpc1788 and lots of other components on the board an needs new programming of the lpc now, and the solide state relay K4 in the picture is leading to knowhere on the board, atleast i couldend find it maybe you can tell me to where the pin goos?
Hi Gopelhu
I have some questions:
1-I have allready ADG1406BRUZ and L9637D on board ( from factory) but cant connect any old car with K-Line ( pls see pics), or need I to order Original ADG1406BRUZ and L9637D ?
2- need I replace also my mof relays if so by which one ?
3-
my intention was to buy a fvdi that 2014 without online funtion because everyone says ( You too ) that this version is the best ,, I am now cheated or this is the correct version?
what do you think about my fvdi? my pcb is not the same as it is described on the ad, seller has changed the pictures when I said it is not fair.
need I to replace more parts ?
thanks for your time
[QUOTE = gopelhu; 3037554] Salut à tous,
2ans 3 mois 6 jours ...... très très longtemps ......
mais j'ai fini de résoudre tous les fwgenerator v34 & v36 .....
seulement pour vous faire connaître ces infos .....
Cordialement, G [/ QUOTE]
Bonjour, j'ai bloqué mon interface Fvdi V4-1 complète J'ai le led rouge clignotant depuis la mise à jour vous pouvez m'aider s'il vous plaît résoudre le problème
Hello, I blocked my interface Fvdi V4-1 complete I have the red led flashing since the update you can help me please solve the problem
Hi!
My interface FlyFVDI 2014 no dongle/softdog - very good clone
I have the same problem with the same car Toyota Avensis with 4A-FE engine
this car can DESTROY any diagnostic with un-proper OBD leads
PLEASE BE AWARE to all users
-NXP LPC1788 is damaged very HOT with 5+USB in)
-multiplexers damaged part U10 U13
I have contacted Fly company and thy give me link to download and program by usb fw.bin wf.bin and db.bin but not work by usb
i need help to program LPC by uart for new LPC1788 installed
FVDI unit
F00316
046001032294BCAE3E230A56C21C00F5
i have fw.bin wf.bin and db.bin they told me to not give to anywone )))
carcode (9th January, 2021), Col19 (8th December, 2020), estwood68 (9th January, 2020), gopelhu (28th January, 2018), guliver21 (18th May, 2020), just4upal (24th January, 2018), mickye_dj (8th September, 2018), Msmax (20th July, 2023), NONO59 (4th December, 2023), Rachon (13th February, 2018), Stelaras26 (7th February, 2018), Talleresmalaga (2nd May, 2020), vari (26th June, 2018), xseva (15th December, 2018)
