I can repair your FVDI: problem SN:00000. Priv
Hi all,
does anyone have fw.bin and db.bin for an FVDI 2014 clone and audiV6-1.pcb ?
First I started to have it in "Interface not calibrated" but I found that there was an hardware failure and it was not getting to the db.bin info. Now I figure out the hardware problem but when I was testing I have updated with wrong fw.bin.
And now I have it in blinking RED and error 4.
I only need the right fw.bin and db.bin, please!
Many thanks!
Hi, i read threads on this forum about fvdi, but i cant find a information about updates. I seen that you research about this interface and software. Is there any way to flash nxp with new version of firmware to use latest software? And i have a problem with my interface im not shure is version of 2014 or 2015 using old software, when i start quick launcher and select some module interface is checked and say connected but when i checking flasher says there is no programmer connected. Also have problem with can line. But this problem is not permanent. when program accsess to programmer then can protocol also work. Do you know anything about this?
Thank you
Hi mate! After lpc 1788 was erased i used your solution posted here,but what is new now the blinking red led change to green and still my interface have new error : comunication timeout.What can i do to bring my interface working again? When i use FWgen v3.4 serial is 0.Thank you in advance!!!
check the latency setting under the Advanced tab of your com port - it should be set to 1 instead of the standard setting 16.....
I have a question for the experts on the topic
I have fvdi v3, led is not lit, no communication via usb
connection with lpc1788 is via uart
how to revive it ?
with a boot.hex file for your v3 pcb...and than fw downloader with proper fw bin and db bin for you interface....
avdı zn051 pdf
roley ???
x1 ?????
THANKS
after 1 year use FVDI pcb audiv6-1
it stop working
no led flashing
can somebody help me ?
it is a example of malfuncion of my tool, https://youtu.be/PakgJH36Olo , need help, problem is of firmware, hardware,... i reinstall software, but problem equal.
do you help me? my provider not respond. this is a clone fvdi2015 version.
this interface work with sw old, for all models of cars, but wit sw new no, for example, if open fiat it have version 5.1 and 5.7 if selection 5.1 then car new not are is included in the list support. if select of version 5.7 not work fine,..
this interface broken all bsi of psa for cars of 2011 year, when write km in bsi, after is repairable writing jci_bsi_xxxx file in the new version, this step work, but the calibration not possible, for it use version old, is very inestable, i thinking of interface is broken, but i do not know where is the problem, i restart computer and reinstall all software, i thinking of problem in the firmware o hardware. help me, please!!!
Original BDM EVC with adapters, SPI EVC, Galep5 programmer, emp11 programmer, upa1.3, kwp2000plus, MPPS, Ktag, Kess, Galletto ofiicial, and many more...
Hi at all,
Very interesting Thread an a good job by member Gopelhu
but no informations of the ,,new'' fvdi
Anyone know the differents between fvdi2 and fvdi2018. Maybe the pcb or only software?
Why the fvdi2 have the vvdi2 4.2.1 software and the fvdi2018 only 1.2.2
On my fvdi2018 vvdi run not so stable and it cant read bcm2.
Vvdi2 4.2.1 can read bcm2 an much more funktions on FVDI2
I think a solution is interesting for all with a normal fvdi.
Perhabs we find a solution to update the fvdi
gopelhu (18th March, 2019)
Pls. need boot file for fvdi 2018
If my post was helpful than Please don't forget to press the Magic word
I bought FVDI 2018 clone made by STIC Company i think, and i am not happy with it,
i try it to do dash on MB W212, W218, W221, and none of them cant correct km
in W212 killed the CGW... now kills itself, no led lights, no usb recognition on computer. . .
It uses LPC1788 as Main Microcontroller and MAXQ1850DS Secure Microcontroller for softdog
i think FVDI 2014 is better and more stable till now.
I think that the bootloader is deleted by server, need to rewrite it via uart,
pls. if someone can help me with boot file for fvdi2018.
