Page 3 of 48 FirstFirst 1234567813 ... LastLast
Results 31 to 45 of 720
  1. #31
    gopelhu's Avatar
    EU
    Hi all,
    Somebody has ds2460 programmer?
    If so, pls pm me.
    http://www.maximintegrated.com/en/pr...0.html/tb_tab0
    Regards, G
  2. #32
    autocheck's Avatar
    Feb 2014
    Zimbabwe
    Can I update my fvdi to have all the 18 activated ? At the moment it does Ford/Mazda and hyundai
  3. #33
    gopelhu's Avatar
    EU
    Quote Originally Posted by andrey31 View Post
    I have an update for fvdi V4 id: F04881 for Ford and Toyota
    https://yadi.sk/d/W5OY3urDbu55n
    Hi Andrey,
    You wrote this ID: F04881 and your file is F08481.
    What is the correct serial number?
    Regards, G
  4. #34
    Oct 2012
  5. The Following User Says Thank You to andrey31 For This Useful Post:
    gopelhu (11th February, 2015)
  6. #35
    Austria
    andrey31
    Am intrested how did you expand your 2014 with additional soft as the fly officialy said that
    thay dont do this anymore.
    As explanation thay said thay have no more licence to expand 2014 version to add other soft/commanders which could indicate thay are acctualy not behind the
    whole project, as someone else is making lic's for tham.
  7. The Following User Says Thank You to oep For This Useful Post:
  8. #36
    overs0ull's Avatar
    Nov 2012
    near the sea ... ;)
    Hy mate i am interesting about you work and i am ready to help you as i can .
    I have a lot of programmers but i am not sure are they can help you - Orange 5 , xprog box 5.5 , ori Upa , and many other if they can read it i will try to help .
    I have FVDI with pcb v3 if you need some pictures tell me . But my unit have problem with K-line connection with all cars and i try to find sollution and i still not chage adg1406bruz and still don't know are is there the problem and i am ready to help as i can
    Chiptuning/DPP/EGR/LAMBDA(O2)/FLAPS/Adblue/DTC OFF / EDC17 Immo OFF
    Kess v2 eu. clone full/Ktag eu. Clone 6.070 full
    Info on pm
    Kess v2 ori , K-tag ori, MAGPro2 x17, Galleto v54 EU ,Winols ,AVDI full ori, Orange 5 /Omega /Xprog/Upa all ori , VAS Pc , Porsche PIWIS 2 and etc........
  9. The Following User Says Thank You to overs0ull For This Useful Post:
  10. #37
    gopelhu's Avatar
    EU
    Quote Originally Posted by overs0ull View Post
    Hi mate,
    If your interface does not works with K-Line, please replace these ics: L9637D (this is ISO K-Line ic) and ADG1406BRUZ multiplexer ic. pls check the attachment.
    The same..... I have beeprog and beeprog2, X-progm, New Upa orig, Ds2432 programmer, carprog full...etc, but none of them read the ds2460.
    I need more pictures an orig avdi interface. ( I have some pictures Fly FVDI/AVDI v3 & v4 & v4-1, Orv commander, SVDI PSA ) but i need an orig avdi pcb pictures
    and I need some pictures for SVDI with macro mode )
    Regards, G
  11. The Following 18 Users Say Thank You to gopelhu For This Useful Post:
    amor89 (12th March, 2017), antonypaul (1st March, 2015), arti1 (27th February, 2016), blackpirate (11th February, 2015), boxsport (9th September, 2019), brodaty (11th February, 2015), carsoftobd (27th January, 2016), Col19 (8th December, 2020), FxShaw (20th July, 2016), gatiss (2nd August, 2023), glk96000 (28th May, 2015), HeXor (9th July, 2015), igorr (11th February, 2015), jnoroeste (22nd March, 2015), mariantv (9th February, 2017), neoronin (10th May, 2015), overs0ull (11th February, 2015)
  12. #38
    gopelhu's Avatar
    EU
    Hi all,
    Here are 2 pics for SVDI pcb without macro mode.
    I need some pics with macro mode.
    Regards,G
  13. The Following User Says Thank You to gopelhu For This Useful Post:
    Col19 (5th October, 2022)
  14. #39
    overs0ull's Avatar
    Nov 2012
    near the sea ... ;)
    I have a friend ho have 2 sets of FVDI one from fly one is 999$ full set if you thing that will help to ask him for pictures if their pcb can help .
    I will ask him are he have DS2432 programmer if he can help . And i will research for this programmer
    Info on pm
  15. The Following User Says Thank You to overs0ull For This Useful Post:
  16. #40
    DK Veteran gedas8899's Avatar
    Dec 2010
    Scandinavia
    i have full soft if you need i can share
  17. The Following 3 Users Say Thank You to gedas8899 For This Useful Post:
    Col19 (8th December, 2020), gopelhu (11th February, 2015), shadab (19th February, 2016)
  18. #41
    gopelhu's Avatar
    EU
    Quote Originally Posted by gedas8899 View Post
    Hi all,
    To inform everyone that I have these software: SVDI FULL, AVDI&FVDI FULL, ORV commander, VAG VVDI Commander, TAGKEY, Some AVDI&FVDI sw wtith different car types, FVDI PSA patch...etc.
    If anybody need it/them I will share but the full version and common sw are big file size (more than 1GB).
    I will upload the patch for PSA, and the seller tell me that this works all FVDI interface. I tested it my AVDI interface (same with FVDI) but without success.
    Pls check it if you have FVDI interface and other sw than PSA ( PSA not calibrated ).
    This patch will does not damaged your interface. I tested it.
    https://mega.co.nz/#!38QDzbLK!PKYfJf...LwAOS8orfg_vok
    Best regards, G
  19. The Following 7 Users Say Thank You to gopelhu For This Useful Post:
    estwood68 (10th January, 2020), jnoroeste (22nd March, 2015), just4upal (16th February, 2016), Kalectro (12th March, 2021), paulolad (1st September, 2018), shadab (19th February, 2016), Talleresmalaga (11th November, 2018)
  20. #42
    gopelhu's Avatar
    EU
    The DS2432 programmer cannot be read the ds2460 ( not supported )
    If somebody know what is the type of programmer that can be read ds2460, pls let me know.
    Regards, G
  21. The Following User Says Thank You to gopelhu For This Useful Post:
  22. #43
    overs0ull's Avatar
    Nov 2012
    near the sea ... ;)
    I did some research for this DS2460 programming and mayby this info will give us some help but i am not sure :
    Silica_Maxim_DSAUTHSK_starter_kit_ds.pdf
    This is a programmer but i don't have any contacts with them , and i didn't know are it support ds2460 but it's not a problem to ask them
    Info on pm
  23. The Following User Says Thank You to overs0ull For This Useful Post:
    gopelhu (12th February, 2015)
  24. #44
    MACKIE's Avatar
    Jan 2011
    Helion Prime
    Quote Originally Posted by gopelhu View Post
    Hi mate,
    Regards, G
    Bro can you please post picture of pcb v4.1
    Mackie
    " I don't need help but difficulties. The harder the better. I work the best when in trouble."
  25. The Following User Says Thank You to MACKIE For This Useful Post:
  26. #45
    gopelhu's Avatar
    EU
    Quote Originally Posted by MACKIE View Post
    Mackie
    Hi bro,
    I got these pics, pls check the attachment.
    Regards, G
  27. The Following 3 Users Say Thank You to gopelhu For This Useful Post:
    MACKIE (13th February, 2015), makadam (28th December, 2022), marsete (4th March, 2018)
