Gopelhu:
My fvdy read edc15 ecus , but For dash RB4 and RB8 ,
need to remove this 3 ic's and make like that picture you showed in previous post ?
Because i dont understand
thx
Gopelhu:
thx
Hi there .
I tried a few cars fly "2015" full version.
-2011 Fiesta dash read, but not write. While writing, direction indicators flash and dismount.
-2012Transit DPF and key fit not to go, but the cause diagnostics.
-2010 Megane dash works.
-2010 Octavia dash ok
-2007 VW T5 dash + ecu "EDC16" eep working. The ECU flash stopped halfway.
-Hyundai Accent, key good fit.
Sorry for my bad english
Hi!
I open the license Ford
When connected constantly writing error 5
I have written to the Chinese who took he sent me an update
I then got an error updated 4 and red light diode
I again wrote to the Chinese but it's gone and is not responsible
Who can I do to help restore my FVDI v 4
Is there any solution to upgrade cheap clone of clone version without ds2460?
No it’s the software, once the license is generated there no reverse solution, I have been checking the licence database it’s all encrypted you just can not get around it, I think there may be a way around it if we can get the virgin database, don’t think cost $$$$$$$$$$....
Thank you for answer. Probably Ill sell it and Ill buy new from fly. Maybe before Christmas they will release new version.
Sent from my D6503 using Tapatalk
He then wrote "error 5" when they are not well installed.Fly wrote, go over only virgin "xp sp2."
if you have error 5, you must use FTDI driver 2.8.14 only that version work with fvdi. fly does not know what he says !!
gopelhu (7th December, 2015)
Hi gopelhu So you recomended fvdy from fly u know how much working of original avdi fro 0 to 100 how much you think is work because I want bay new fvdi 2016 gary of flay hi want 4600 usd thanks in advance
Already we solved the problem by FVDI
2014-2015 any PCB v3 v4 or v4-1
You can restore the red LED
or when the LED does not light up
The DS2460 is a co-processor memory, but you will read with 24LC512 eeprom solution.
The pinout is a different with I2C eeprom pinout, bec 1-4 pins as the same, 5pin NC, 6pin SDA, 7pind SCL, 8pin VCC (3V3).
https://datasheets.maximintegrated.com/en/ds/DS2460.pdf
Regards, G
