Page 32 of 48 FirstFirst ... 22272829303132333435363742 ... LastLast
Results 466 to 480 of 720
  1. #466
    Please, nobody know what is this component? Abrites team don't want to repair it because i opened it to repair myself (avdi isn't under garanty)
  2. #467
    yellowstilo's Avatar
    a better picture would help to get your answer....
  3. #468
    Exclamation
    Here my board with component missing
    thanx
    Quote Originally Posted by yellowstilo View Post
  4. #469
    it should be a 220 ohm resistor, there is another one at the opposite behind the USB connector and in between are two capacitors with unknown value, try with 10 or 100 nF when you need those too (picture is still crap, too small to see any details...)
  5. #470
    hello, i sent last pictures with my phone and with my laptop i saw they are s...t pictures . Please have a look to this one, it miss one component in my board and i surrounded it in red
    Thank you
  6. #471
    on mine it's a 22 ohm resistor (code 220) just like the one at the other side of the USB connector - in your case they mounted a 27 ohm resistor (code 270) so you might put a 27 ohm for balance....
  7. The Following User Says Thank You to yellowstilo For This Useful Post:
    james44000 (13th September, 2018)
  8. #472
    Ok thanx il will try this
  9. #473
    Sep 2016
    thank you for your the information
  10. #474
    Dr Alex's Avatar
    Mar 2016
    hello friends,i have original fvdi from fly and now is nothing light up the led,only got red/green from softdog.
    also not recognise usb.any solution for this?
  11. #475
    May 2018
    hi. I want to read lpc, but how bypas security
    no erase.
  12. #476
    Dec 2015
    Germany
    the same question
  13. #477
    Oct 2018
    Hello, i have FVDI 2016 from flyobd.com and after connecting to the server device stopped working. Green/red light on FVDI is not flashing, no response, pc won't detect. Dongle (red dongle) red/green flashing. Is the solution to this problem found?The device send for reinstatement to a factory in China and received back.After a month of work ,it was blocked again.
  14. #478
    Aug 2014
    Default v36
    hi,
    FWGenerator v36
  15. The Following 14 Users Say Thank You to Phrozen For This Useful Post:
    BUSUIOKPETRU (1st February, 2019), carsoftobd (11th January, 2019), Col19 (8th December, 2020), estwood68 (10th January, 2020), guliver21 (19th May, 2020), laki23 (22nd January, 2020), mkii (25th February, 2024), NONO59 (4th December, 2023), Ocis (20th January, 2019), oldero (11th February, 2022), Romanki (21st May, 2022), tawaf111 (23rd July, 2019), vavrich (7th July, 2020), zazd (22nd February, 2019)
  16. #479
    Dec 2015
    Germany
    Quote Originally Posted by Phrozen View Post
    hi,
    FWGenerator v36
    Has anyone tried it?
  17. #480
    Oct 2010
    Hey guys,
    i reworked my key tag tool a week ago with 680pf ceramic condensator,
    bought 2 transponders id46 pcf7936, i only could identify 1 of 2 (programmed the one identified)
    i then ordered another 2 and i cant identify nor read them, afterwards i could get another two transponders and those arent working either, so my question is i read something about 4 byte in this thread -> what is the issue?
    EDIT: turns out the ones i received from the dealer dont work, bought from different guys on ebay and they do work fine!
