Page 6 of 48 FirstFirst 123456789101116 ... LastLast
Results 76 to 90 of 720
  1. #76
    konq100's Avatar
    Oct 2013
    Sofia, Bulgaria
    Quote Originally Posted by overs0ull View Post
    guys please can someone tell me what is the resistance of the smd resistor C23 on the left side of adg1406bruz cause maybe i kill my one .
    I desoldered it and the multimeter can't catch it on 200 m.ohm
    C23 = 100nF = 0.1?F
    p.s info from datasheet.
    Regards.
  2. The Following 3 Users Say Thank You to konq100 For This Useful Post:
    Col19 (8th December, 2020), gopelhu (19th February, 2015), overs0ull (20th February, 2015)
  3. #77
    gopelhu's Avatar
    EU
    Yes u are right!!!
    C1,3,4,6,9,10,12,13,14,16,23,24,26,29,30,33,43,46, 47,49,50 are them 100nF.
    Regards,G
  4. The Following 4 Users Say Thank You to gopelhu For This Useful Post:
    Col19 (8th December, 2020), gziro (28th February, 2018), konq100 (19th February, 2015), overs0ull (20th February, 2015)
  5. #78
    MACKIE's Avatar
    Jan 2011
    Helion Prime
    Quote Originally Posted by salkapone View Post
    da radi,,,sad neznam sta neradi ,a sigurno neradi kako treba,,,,danas ga dobio i probao na astri h pin iz ecu o.k,,,skoda octavia2 pin iz sata o.k,,,fiat iaw 59f procitao eprom,,,kilometre na puntu 2003 uradio kako teba,,,,ford na canu nista nece samo procita kilometre,,,dali cu postici ista sa ovim relejima
    to work ,,, now I do not know what reluctantly, and certainly reluctant to be ,,,, got it today and tried to astra h pin from the ECU ok ,,, SKODA octavia2 pin from DASH ok ,,, fiat IAW 59F read eprom make virgien o.k,, , ,,,, ford on the can of nothing would only read the kilometers but not calibrate ,,, if I am going to achieve the same with these relays
    This interface will not work without mosfet swiches so I dont know how you manage to connect with car...i try on couple Iaw's , Fiat cars with can-ex and try on VW with K line and nothing happend.... then opened interface and see this....they just forgot to put it there...and interface will not work without them ...everything else is ok...usb connection etc...
    Mackie
    " I don't need help but difficulties. The harder the better. I work the best when in trouble."
  6. The Following User Says Thank You to MACKIE For This Useful Post:
    gopelhu (20th February, 2015)
  7. #79
    overs0ull's Avatar
    Nov 2012
    near the sea ... ;)
    Thanks guy yes my bad cappasitor not resistor i will change it .
    After some soldering of the adg and L9637D have a GOOD news - it start to wokr via k-line on audi i try 2 cars and work stable on :
    -audi a4 b5 1.9 tdi v18 work good v21 crash some times not stablle
    -vw passat b5.5 1.9 tdi 131 v18 and v21 work fine .
    Now the next test will be on french cars and UDS are will start to work fine with them .
    I will update info later after some more test .
    AGAIN big tanks to helping .
    Gope you will win the batlle just need time and some patience .
    Chiptuning/DPP/EGR/LAMBDA(O2)/FLAPS/Adblue/DTC OFF / EDC17 Immo OFF
    Kess v2 eu. clone full/Ktag eu. Clone 6.070 full
    Info on pm
    Kess v2 ori , K-tag ori, MAGPro2 x17, Galleto v54 EU ,Winols ,AVDI full ori, Orange 5 /Omega /Xprog/Upa all ori , VAS Pc , Porsche PIWIS 2 and etc........
  8. The Following 4 Users Say Thank You to overs0ull For This Useful Post:
    Col19 (5th October, 2022), glk96000 (28th May, 2015), gopelhu (20th February, 2015), power1977 (11th October, 2016)
  9. #80
    gopelhu's Avatar
    EU
    I am glad that the interfaces working again, and I hope I can still help.
    Test several cars.
    Warning to everyone !!!
    Renault Megane2 Dump tool maybe can kill the interface.
    The LPC die !!!
    Now I repair and tested it one of these and the result, the LPC died.
    X1 Xtalk two pins become shorted. Grrrrrrrrrrrrrrrrrrrrrrr
    Reagrds, G
  10. The Following 2 Users Say Thank You to gopelhu For This Useful Post:
    igorr (22nd February, 2015), overs0ull (20th February, 2015)
  11. #81
    overs0ull's Avatar
    Nov 2012
    near the sea ... ;)
    LOL that sound sh*ty pff, are it can be repaired .
    -Now tested Golf 4 1.9 tdi PD 101h.p 2001 k-line work fine(connect to all availble moduls) but when i start live data the software crash every time doesn't metter v8 , v18 and v21 not stablle ,on abs ,and other moduls ok but on engine live data crash . on Audi a4 b5 and passat b5.5 ok not crash on live data.
    -Other thing witch i test is k-line instrument cluster to read mealege and pin code but after 10 min nothing, the instrument cluster is VDO but not read it , don't know are need to wait more time or the software and firmware need to be updated .
    Info on pm
  12. The Following User Says Thank You to overs0ull For This Useful Post:
  13. #82
    ruffles1986's Avatar
    Sep 2011
    In the Garage
    Quote Originally Posted by gopelhu View Post
    Hi all,
    Somebody has ds2460 programmer?
    If so, pls pm me.
    http://www.maximintegrated.com/en/pr...0.html/tb_tab0
    Regards, G
    Maybe is more cheaper send it to chinese crackers icunlock-mcucrack.com/
  14. The Following User Says Thank You to ruffles1986 For This Useful Post:
    gopelhu (21st February, 2015)
  15. #83
    gopelhu's Avatar
    EU
    Quote Originally Posted by ruffles1986 View Post
    Thank for help but as a long-time Chinese companies need a solution.
    Not to mention the post office either ( shipping and handling time ).
    But I need a good programmer that his can be read/Write this DS2460.
    About: I changed my avdi interface <=> damaged interface to DS2460.
    Result: DS2460 NOT a stored any serial !!! It is cryptowork ic, maybe ?!
    When I read it success that I will have any result.
    Regards, G
  16. The Following User Says Thank You to gopelhu For This Useful Post:
    lupus80 (4th December, 2023)
  17. #84
    gopelhu's Avatar
    EU
    Hi all,
    I'll upload a few pictures from damaged V3 interface.
    The result: LPC damaged.
    I ask everyone who has this type of ground was purchased inteface to be very careful to stay cool !!!
    When I upped all the VDD pins removes the short to ground.
    If you are very deep in the sand when it warms up then it ruptures and goes short to ground.
    It may even be bent!!!
    Regards, G
  18. The Following 6 Users Say Thank You to gopelhu For This Useful Post:
    ayoub3030 (5th March, 2015), bawareca (27th February, 2015), Col19 (8th December, 2020), overs0ull (25th February, 2015), ovi_dk (5th March, 2015), Talleresmalaga (1st May, 2020)
  19. #85
    gopelhu's Avatar
    EU
    Hi all,
    If someone is on sale old AVDI/FVDI interface with PSA sw, then let me know in pm.
    Thank you.
    Regards, G
  20. #86
    here
    i have it with renault software
  21. The Following User Says Thank You to smt For This Useful Post:
    gopelhu (28th February, 2015)
  22. #87
    leandroks's Avatar
    Brazil
    Hi guys, i can see u r the fvdi masters, so maybe one of u could get me a hand, my fvdi is working ok, but when i need to use antenna (like on making dealer vag keys or on tag programmer) i always got the same message "Programmer not conneted" i ve bought another antenna programmer but still the same.
    Any idea?>>>
    Thanks in advance
    BR
    Leo
  23. #88
    gopelhu's Avatar
    EU
    Quote Originally Posted by leandroks View Post
    Any idea?>>>
    Thanks in advance
    BR
    Leo
    Hi Leo,
    Your antenna pcb is old or new version?
    Here is the pic the new version.
    Maybe you will need resolder the pic component and pls check all (Q) parst FET.
    If all of them OK, pls check your AVDI/FVDI interface all solder pad.
    Regards, G
  24. The Following 3 Users Say Thank You to gopelhu For This Useful Post:
    Col19 (8th December, 2020), leandroks (28th February, 2015), Talleresmalaga (1st May, 2020)
  25. #89
    leandroks's Avatar
    Brazil
    Hi m8 thanks a lot, i ve resoldering all the components antenna and fvdi pcb, but still no luck.
    My antenna is the one on your picture.
    Any other idea??
    Leo
  26. The Following User Says Thank You to leandroks For This Useful Post:
  27. #90
    gopelhu's Avatar
    EU
    Any other idea??
    Leo
    I have an other idea.
    Do you have any other interface ( ORV, tagkey or VVDI or svdi )?
    If so, pls connect the other interface with the old sw and test it.
    I tested my other old ORV and the result. Old sw updated this new pcb and when i updated with new sw then result, again updated and works perfectly.
    Try this solution...
    Regards, G
  28. The Following 3 Users Say Thank You to gopelhu For This Useful Post:
    ayoub3030 (5th March, 2015), MACKIE (24th April, 2015), ovi_dk (5th March, 2015)
