Page 7 of 48 FirstFirst ... 2345678910111217 ... LastLast
Results 91 to 105 of 720
  1. #91
    May 2013
    UK
    hi anybody have dead fvdi ? no led flashing and computer dont see this chinese black box. Everything go dead after 6 plug ins to usb port before everything was ok. Any solutions ? chinese man dosnt respond
  2. #92
    securipro38's Avatar
    EU
    If your fvdi is not detected by computer ,you should have a look fvdi usb connector ,interfaces chinese usb B connector bad quality ,verifiy if you can see 4 pins ,one of them could stay blocked ,I had this problem with even original AVDI
  3. The Following 2 Users Say Thank You to securipro38 For This Useful Post:
    bawareca (13th March, 2015), gopelhu (13th March, 2015)
  4. #93
    gopelhu's Avatar
    EU
    Quote Originally Posted by monter8484 View Post
    Pls open your interface without plugged any usb !!! It is important !!!
    Check the X1 Xtal component with multimeter two pins. If the multimeter beeeeeep then you LPC processor is damaged !!!
    After pls check C39 capacitor and if the multimeter again beeeeep then 100% your interface LPC proc is DAMAGED.
    You will be return your china seller to repaire. Or pls write me pm.
    Regards, G
  5. The Following 6 Users Say Thank You to gopelhu For This Useful Post:
    Col19 (5th October, 2022), igorr (14th March, 2015), Kalectro (12th March, 2021), konop11138 (2nd November, 2017), overs0ull (13th March, 2015), taxo1965 (15th July, 2018)
  6. #94
    overs0ull's Avatar
    Nov 2012
    near the sea ... ;)
    Lol mate you give him a hope i like you :P
    How is going the fproject any new victory
    Chiptuning/DPP/EGR/LAMBDA(O2)/FLAPS/Adblue/DTC OFF / EDC17 Immo OFF
    Kess v2 eu. clone full/Ktag eu. Clone 6.070 full
    Info on pm
    Kess v2 ori , K-tag ori, MAGPro2 x17, Galleto v54 EU ,Winols ,AVDI full ori, Orange 5 /Omega /Xprog/Upa all ori , VAS Pc , Porsche PIWIS 2 and etc........
  7. The Following 2 Users Say Thank You to overs0ull For This Useful Post:
    gopelhu (13th March, 2015), igorr (14th March, 2015)
  8. #95
    gopelhu's Avatar
    EU
    Default orig avdi
    Hi all,
    Now I still working my project, but I have some solution !!!
    Abouth, somebody know what are the two components for ORIG AVDI?
    If so, pls let me know.
    Thank you, G
  9. #96
    konq100's Avatar
    Oct 2013
    Sofia, Bulgaria
    Looks like tantalum capacitor.
  10. #97
    gopelhu's Avatar
    EU
    NOT, maybe Dioda as I know, but which?
  11. #98
    DK Veteran kelekele's Avatar
    Sonta,Serbia
    This 2 components is simply(not zener or other types) diodes,used for filtering voltage or switched supply.
  12. The Following 3 Users Say Thank You to kelekele For This Useful Post:
    andkl2810 (14th March, 2015), Col19 (5th October, 2022), gopelhu (14th March, 2015)
  13. #99
    DK Veteran andrym3's Avatar
    diode left rotection reversing polarity
    diode right :switched supply
  14. The Following 2 Users Say Thank You to andrym3 For This Useful Post:
    andkl2810 (14th March, 2015), gopelhu (14th March, 2015)
  15. #100
    You can use any diode rectifier
  16. The Following User Says Thank You to andrym3 For This Useful Post:
  17. #101
    gopelhu's Avatar
    EU
    Can I use normal dioda or bipolar dioda?
  18. #102
    diode normal rectifier like serie 1N4001,2.....7.
  19. The Following User Says Thank You to andrym3 For This Useful Post:
  20. #103
    gopelhu's Avatar
    EU
    Hi all,
    Pls check the attachment, I found this Dioda an other orig AVDI.
    What is this marking code? I checked with systek.ru but without success.
    This website is a best these marking code
    Regards, G
  21. #104
    Moderator
    PremierD's Avatar
    Jun 2009
  22. The Following User Says Thank You to PremierD For This Useful Post:
  23. #105
    gopelhu's Avatar
    EU
    Quote Originally Posted by PremierD View Post
    Thank you so much, yes you are the correct parts...
    Regards, G
