gopelhu (15th March, 2015)
Hi all,
Here is my other project !!!
Still working this, but when I received my 3pces AVDI and FVDI then will be finished 2 weeks.
Furthermore, somebody has SVDI damaged version? If so, pls pm me.
Regards, G
alfons37 (21st March, 2015), andrym3 (22nd March, 2015), blackpirate (21st March, 2015), Col19 (8th December, 2020), Himik777 (27th April, 2016), igorr (23rd March, 2015), jnoroeste (22nd March, 2015), lidons (22nd March, 2015), makadam (28th December, 2022), mihaiservice (22nd March, 2015), moldo25 (5th April, 2023), monter8484 (22nd March, 2015), NONO59 (4th December, 2023), overs0ull (29th March, 2015), Siham (1st April, 2015), sweetsamo (21st September, 2016), Talleresmalaga (1st May, 2020), u.s (21st March, 2015), xanubysx (26th March, 2015), yellowstilo (21st March, 2015)
mate did - are that was what it thing ?
-You can read/write the fvdi firmware and change it or no , and unclock them .
this is look nice
Chiptuning/DPP/EGR/LAMBDA(O2)/FLAPS/Adblue/DTC OFF / EDC17 Immo OFF
Kess v2 eu. clone full/Ktag eu. Clone 6.070 full
Info on pm
Kess v2 ori , K-tag ori, MAGPro2 x17, Galleto v54 EU ,Winols ,AVDI full ori, Orange 5 /Omega /Xprog/Upa all ori , VAS Pc , Porsche PIWIS 2 and etc........
Simple way to detect does diode is zener is to remove it from pcb, use 1K resistor in serial, connect it on 12Vdc revers polarity and measure voltage on it... if have less then 12V, it is zener diode...
Great job !!
Maybe it will also possible to upgrade original AVDI and add some functions,or just for FVDI!
No thank , no HELP .
gopelhu (1st April, 2015)
Hi all,
I'm looking for the original fly FVDI is what this chipid thereof : 080D070700003253610B3D52070000F5 !!!!
The fly clone of clone of clones all have the same chipid, but the serial number is only a 0th. The label serial are differents: F08150, F06909, F07051...etc.
If somebody has the orig fly interface which the chipid is this, and If the PCB is a sticker with the same serial number as in the box, let me know the serial number, and his chipid.
Thank you.
Regards, G
Hi all,
I found one more clone of clone serial, here is FVDI F07458 which chipid as the same 080D070700003253610B3D52070000F5.
Regards, G
Hi all,
Sorry to all, but now I will go to country side. Will be back later.....
Regards, G
lidons (13th April, 2015)
I Bought fvdi and to my surprise not work on VAG EDC15
I Changed adg1406bruz and l9637D, MOSFET swiches, short pin 6 9637d and pin4 K6 swiches MOSFET (k-line pin7 OBD)
but still can not connect the line k EDC15
does anyone have another solution or is a bag of software
you need it from old fvdi or new fvdi 2015 ??
marwo (7th June, 2020)
was recently bought on AliExpress 30/03/2015
model 18 software activated
a reading series and post here tonight
Can you tell me your FVDI Chipid and serial with fwgenerator?
as I can do this?
excuse my English, is the best.
chipid : 080D070700003253610B3D52070000F5
serial : 0
pcb version V4-1 without ds2460
on the box write F06410
Your FVDI is clone of clone of clone.
I tested one clone of clone of clone FVDI and here are the results: works max 30% , the flash MX29GL256 is locked and You can not update the database.
You should find the interface with the same chipid and you should be able to fly company serial number.
If this happens, it will be possible to upgrade, but then only the firmware.
Regards, G
taxo1965 (14th July, 2018)
