Page 24 of 48 FirstFirst ... 14192021222324252627282934 ... LastLast
Results 346 to 360 of 720
  1. #346
    Nov 2015
    Lublin/poland
    hello firends i have problem
    bouy used fvdi v2015 id:f07627
    instal quick loader commander v6.0 only work audi v8.6 ( Other bookmarks = error interface not calibrated )
    instal quick loader commander v6.3 nothing works ( error interface not calibrated )
  2. The Following User Says Thank You to kostrz3 For This Useful Post:
    kamionk (10th October, 2019)
  3. #347
    Ahmy501's Avatar
    Jun 2016
    Has any one used a cloned adapter J1850 with FVDI. i need directions whether to buy it or not.
    I know the original adapter doesn`t work with clone FVDI
  4. #348
    Mar 2017
    Hello I changed the microcontroller LPC1788 of my interface I would like to have the program to be reinjected inside. My interface is a clone in pcb version 4-1. I have the full 2014 version without sofdog! My serial number is F00571. Thank you
  5. #349
    Dziwak's Avatar
    Jun 2014
    UK
    Did any one of you had a problem on Opel/Vauxhall it connects to all modules on Kline/KWP Can High MID but can't connect to CAN LOW any solutions? maybe relay fault what do you think guys: ?
  6. #350
    gopelhu's Avatar
    Jan 2010
    EU
    Quote Originally Posted by kostrz3 View Post
    hi
    write me a pm
    regards, G
  7. The Following User Says Thank You to gopelhu For This Useful Post:
    kostrz3 (24th April, 2017)
  8. #351
    Apr 2017
    hello friends, My genuine AVDI don't communicate with CAN protocole, It's work great with K line, tag tool work fine too, but CAN no, any help please?
    thanks.
  9. #352
    Aug 2015
    you really should contact dealer in case of original tool...
  10. #353
    Apr 2017
    Hi, i contact abritus support, he said me to send device to Bulgaria, it's so difficult to do, so I project to exchange adg 1406BRUZ, I don't know if it is the best solution?
    regards.
  11. #354
    doctore's Avatar
    Nov 2015
    Colorado Denver
    Quote Originally Posted by servicekey View Post
    regards.
    for that tool it is the best solution
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  12. #355
    Nov 2010
    Default SMD element on Abritus PCB
    May be somebody can help with name SMD element on Abritus PCB (red element)
  13. #356
    gopelhu's Avatar
    Jan 2010
    EU
    Hi all,
    Before anybody will buying the orig fly company products ( FVDI+softdog) pls read this info:
    Blacklist & chip erasing online function.
    Pls read carefull and pls understand, that is why that stoping functionally all red fvdi with softdog.
    Regards, G
  14. #357
    gopelhu's Avatar
    Jan 2010
    EU
    thanks.
    Which version do you have it?
    Regards, G
  15. #358
    Jul 2010
    UK
    image.jpgI have FVDI of 2015 full software, with pcb Audi v6-1pcb, every time I plug into any car it makes noise but works, had to modify the tag tool to read transponders also,
    can anyone point me in the write direction about the noise
  16. #359
    hackgsm's Avatar
    Sep 2009
    change this comp
  17. The Following User Says Thank You to hackgsm For This Useful Post:
    Col19 (8th December, 2020)
  18. #360
    gopelhu's Avatar
    Jan 2010
    EU
    Default succes to finished
    Hi all,
    2years 3months 6days...... very very long time......
    but i finished to solved all fwgenerator v34 & v36.....
    only to let you know these infos.....
    Regards,G
  19. The Following 14 Users Say Thank You to gopelhu For This Useful Post:
    baskom (11th July, 2017), Col19 (5th October, 2022), elchip (27th November, 2017), glk96000 (28th May, 2017), igorr (27th May, 2017), just4upal (26th May, 2017), lidons (24th May, 2017), maiser91 (12th January, 2018), makadam (28th December, 2022), Panora (30th June, 2017), razor1199 (30th January, 2018), sepistar (24th May, 2017), taxo1965 (14th July, 2018), yahia1908 (30th September, 2017)
