From my experience, turn on engine to have more volts during coding or connect charger.
I thinks it's more of a procedural problem, need to know the process of coding it. Also my car is 2.5L which is not in AVDI .
Sent from iPhone 4S
give me your coding and I will check, maybe byte 15 is not correct for 2,5l engine
Will you put up an autoscan please?
Ronan
It's not complete coding, there is no start/stop info, size of brakes, no engine type, steering wheel is on which side?
Here is for steering on left side:
323B401609260EFB4C1102E4901C7051350000
This coding is for start stop, if it will be without, there would be 41 in byte 15.
can u please help me with a code for a 2004 tdi golf 5 140 hp engine bkd vin WVWZZZ1KZ4B000953
i want to instal a ..BE pump,doing a retrofit of park assist (i olso have tpms reset button)
can u give me bouth codes with & without park assist because i am instaling the pump first an after a couple of weeks the park assist
thanks you all for the help
Which PLA you want to install? 1.5 or 2.0? And on which you have steering wheel?
Base vag abs coding
coding ABS VAG BASE.zip
BUSUIOKPETRU (6th March, 2021), doaa (13th August, 2017), dorcky (7th March, 2023), mickye_dj (2nd November, 2018), workas (24th September, 2016)
the kit i have is 2.0 3AA 919 475 H... steering wheel 1K0 953 549 AQ (1.5 ,do i need to upgrade to ch?) on the left side
ps i well post a complete scan of the car tomorow.
Thanks a lot for helping me
