Log-PROJECT X- WVWZZZ1KZ4B000953.txt this is the scan
thanks for the heads up i will read more about the steering rack(do you recomend one?part number?)
thanks for the help hope the best for all
Hera is a list of Steering racks:
All GEN3 can work with PLA, in older if you see [10], it will work with PLAREDIRECT,1Kx-909-14x-V1.CLB,1K?-909-143-??? ; ZF GEN1 (LHD)
REDIRECT,1Kx-909-14x-V1.CLB,1K1-909-144-E ; ZF GEN1 (LHD)
REDIRECT,1Kx-909-14x-V1.CLB,1K1-909-144-F ; ZF GEN1 (LHD) [10]
REDIRECT,1Kx-909-14x-V1.CLB,1K1-909-144-G ; ZF GEN1 (LHD) [10] 01 02
REDIRECT,1Kx-909-14x-V1.CLB,1K1-909-144-H ; ZF GEN1 (LHD) Har MB 009
REDIRECT,1Kx-909-14x-V1.CLB,1K1-909-144-J ; ZF GEN1 (LHD)
REDIRECT,1Kx-909-14x-V1.CLB,1K1-909-144-F ; ZF GEN1 (LHD) Har MB 009 [10] 01 02
REDIRECT,1Kx-909-14x-V1.CLB,1K1-909-144-K ; ZF GEN1 (LHD) ?? Har MB 009
REDIRECT,1Kx-909-144-V2.CLB,1K1-909-144-L ; ZF GEN2 (LHD) [10] 02 03 04
REDIRECT,1Kx-909-144-V2.CLB,1K1-909-144-M ; ZF GEN2 (LHD) [10] 02 03 04 05 07
REDIRECT,1Kx-909-144-V2.CLB,1K2-909-144-??? ; ZF GEN2 (RHD)
REDIRECT,1Kx-909-144-V3.CLB,1K0-909-144-??? ; ZF GEN3
; 1K0-909-144-C ZF GEN3
; 1K0-909-144-E ZF GEN3
; 1K0-909-144-H ZF GEN3
; 1K0-909-144-J ZF GEN3
; 1K0-909-144-M ZF GEN3
; 1K0-909-144-P ZF GEN3
;REDIRECT,1K1-909-143-44.CLB,1K?-909-143-??? ; ZF GEN1 (LHD)
;REDIRECT,1K1-909-143-44.CLB,1K1-909-144-E ; ZF GEN1 (LHD)
;REDIRECT,1K1-909-144-44.CLB,1K1-909-144-L ; ZF GEN2 (LHD) [10] 02 03 04
;REDIRECT,1K0-909-144-44.CLB,1K0-909-144-??? ; ZF GEN3
BTW, you have really strange 46 module, i can't be found in ETKA
the code does not work getting the error Coding Rejected Error 31 request out of range...
Please help
Try use this one, with turned engine on:
113B400D092200FA881402E9901C0061350800
The code workt the first time but...after doing the basic settings 66,63.60....the pump went back to zeroes
Tryd to use the same code and the error pups back coding rejected....31...
went to someone with a genuine cable used the same code and workt!
deleted all the errors performt all the basic settings, but one keps reapering :
Address 03: ABS Brakes Labels: 1K0-907-379-60EC1F.clb
Control Module Part Number: 1K0 907 379 BE HW: 1K0 907 379 BE
Component and/or Version: ESP MK60EC1 H31 0108
Software Coding: 113B400D092200FA881402E9901C0061350800
Work Shop Code: WSC 33361 790 00999
VCID: 76E59083C145EFAEB11-8023
1 Fault Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Freeze Frame:
Fault Status: 00100101
Fault Priority: 1
Fault Frequency: 1
Reset counter: 126
Mileage: 263667 km
Time Indication: 0
Freeze Frame:
Count: 3
Count: 32768
Count: 12800
Count: 143
Count: 50432
Count: 0
Count: 249
Count: 0
what do u reconmend? thanks again for ewerithing
In documentation from VW I found this procedure:
After the update the following steps must be carried out:
• Code the ABS control unit J104 (as necessary)
• Basic settings of steering angle sensor -G85
• Basic settings of lateral acceleration sensor -G200
• Basic settings of brake pressure sensor -G201
• Basic settings of wheel speed sender -G202
• Basic settings of longitudinal acceleration sensor -G251
• Delete the memory
Avec auto com facilement
Envoy? de mon C6603 en utilisant Tapatalk
costi88 you can try and update the firmware from your 1K0 907 379 BE SW 0108 to 1K0 907 379 BJ 0120
Solved the problem with a replacement part,installt it did the basic settings NEVER (DONT DO IT)toucht the valve seting and warks like a charm!!
Morfej, interesting approach on the problem can i ask how its that done or by who?i allways thout the vw dealers r capable to get it done
Once again thank you all for the support.
Hello, so there should be no issue going from 1K0 907 379 AN to 1K0 907 379 BJ? Have tried to use same coding and adding zeros to no avail...
"out of range"
Where you have seen info that AN can be updated to BJ ?
Only I have seen 1K0907379AN with 0109 software update.
Sorry I meant, can I put the BJ in place of the AN. Was worried I couldn't as had trouble getting coding to work. After running the car for a while and leaving it on I got the code to go in. Then found out you need to calibrate the steering position sensor etc to get it to stick...
Dear 1 6 D, i have a 2009 golf 6 highline 1,4 caxa motronic left side drive. The car gives the "abs code code control unit" not coded or configuration not found error on my mechanics delphi software. When we enter cod control unit for set, we saw 8 pieces double digit, 16 (i think hexadecimal or somethink) value. I cant find the code like this anywhere. Can you help me with that? If you can calculate long code for me, which informations do you need and which hardware and software should ı use?
