Page 3 of 7 FirstFirst 1234567 LastLast
Results 31 to 45 of 96
  1. #31
    May 2010
    Poland
    This should be basic coding without PLA:
    113B400C092200FA881402E9901C0061350800
    Have you changed steering rack? Probably original will not work with PLA and doesn't have DSR function.
  2. #32
    Mar 2016
    Log-PROJECT X- WVWZZZ1KZ4B000953.txt this is the scan
    thanks for the heads up i will read more about the steering rack(do you recomend one?part number?)
    thanks for the help hope the best for all
  3. #33
    May 2010
    Poland
    Hera is a list of Steering racks:
    REDIRECT,1Kx-909-14x-V1.CLB,1K?-909-143-??? ; ZF GEN1 (LHD)
    REDIRECT,1Kx-909-14x-V1.CLB,1K1-909-144-E ; ZF GEN1 (LHD)
    REDIRECT,1Kx-909-14x-V1.CLB,1K1-909-144-F ; ZF GEN1 (LHD) [10]
    REDIRECT,1Kx-909-14x-V1.CLB,1K1-909-144-G ; ZF GEN1 (LHD) [10] 01 02
    REDIRECT,1Kx-909-14x-V1.CLB,1K1-909-144-H ; ZF GEN1 (LHD) Har MB 009
    REDIRECT,1Kx-909-14x-V1.CLB,1K1-909-144-J ; ZF GEN1 (LHD)
    REDIRECT,1Kx-909-14x-V1.CLB,1K1-909-144-F ; ZF GEN1 (LHD) Har MB 009 [10] 01 02
    REDIRECT,1Kx-909-14x-V1.CLB,1K1-909-144-K ; ZF GEN1 (LHD) ?? Har MB 009
    REDIRECT,1Kx-909-144-V2.CLB,1K1-909-144-L ; ZF GEN2 (LHD) [10] 02 03 04
    REDIRECT,1Kx-909-144-V2.CLB,1K1-909-144-M ; ZF GEN2 (LHD) [10] 02 03 04 05 07
    REDIRECT,1Kx-909-144-V2.CLB,1K2-909-144-??? ; ZF GEN2 (RHD)
    REDIRECT,1Kx-909-144-V3.CLB,1K0-909-144-??? ; ZF GEN3
    ; 1K0-909-144-C ZF GEN3
    ; 1K0-909-144-E ZF GEN3
    ; 1K0-909-144-H ZF GEN3
    ; 1K0-909-144-J ZF GEN3
    ; 1K0-909-144-M ZF GEN3
    ; 1K0-909-144-P ZF GEN3
    ;REDIRECT,1K1-909-143-44.CLB,1K?-909-143-??? ; ZF GEN1 (LHD)
    ;REDIRECT,1K1-909-143-44.CLB,1K1-909-144-E ; ZF GEN1 (LHD)
    ;REDIRECT,1K1-909-144-44.CLB,1K1-909-144-L ; ZF GEN2 (LHD) [10] 02 03 04
    ;REDIRECT,1K0-909-144-44.CLB,1K0-909-144-??? ; ZF GEN3
    All GEN3 can work with PLA, in older if you see [10], it will work with PLA
    BTW, you have really strange 46 module, i can't be found in ETKA
  4. #34
    Mar 2016
    the code does not work getting the error Coding Rejected Error 31 request out of range...
    Please help
  5. #35
    May 2010
    Poland
    Try use this one, with turned engine on:
    113B400D092200FA881402E9901C0061350800
  6. #36
    Mar 2016
    The code workt the first time but...after doing the basic settings 66,63.60....the pump went back to zeroes
    Tryd to use the same code and the error pups back coding rejected....31...
  7. #37
    Mar 2016
    Default Update
    went to someone with a genuine cable used the same code and workt!
    deleted all the errors performt all the basic settings, but one keps reapering :
    Address 03: ABS Brakes Labels: 1K0-907-379-60EC1F.clb
    Control Module Part Number: 1K0 907 379 BE HW: 1K0 907 379 BE
    Component and/or Version: ESP MK60EC1 H31 0108
    Software Coding: 113B400D092200FA881402E9901C0061350800
    Work Shop Code: WSC 33361 790 00999
    VCID: 76E59083C145EFAEB11-8023
    1 Fault Found:
    00003 - Control Module
    005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    Freeze Frame:
    Fault Status: 00100101
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 126
    Mileage: 263667 km
    Time Indication: 0
    Freeze Frame:
    Count: 3
    Count: 32768
    Count: 12800
    Count: 143
    Count: 50432
    Count: 0
    Count: 249
    Count: 0
    what do u reconmend? thanks again for ewerithing
  8. #38
    May 2010
    Poland
    In documentation from VW I found this procedure:
    After the update the following steps must be carried out:
    Code the ABS control unit J104 (as necessary)
    Basic settings of steering angle sensor -G85
    Basic settings of lateral acceleration sensor -G200
    Basic settings of brake pressure sensor -G201
    Basic settings of wheel speed sender -G202
    Basic settings of longitudinal acceleration sensor -G251
    Delete the memory
  9. #39
    Jun 2016
    Avec auto com facilement
    Envoy? de mon C6603 en utilisant Tapatalk
  10. #40
    morfej's Avatar
    Dec 2008
    costi88 you can try and update the firmware from your 1K0 907 379 BE SW 0108 to 1K0 907 379 BJ 0120
  11. #41
    Mar 2016
    Solved the problem with a replacement part,installt it did the basic settings NEVER (DONT DO IT)toucht the valve seting and warks like a charm!!
    Morfej, interesting approach on the problem can i ask how its that done or by who?i allways thout the vw dealers r capable to get it done
    Once again thank you all for the support.
  12. #42
    Jul 2016
    Hello, so there should be no issue going from 1K0 907 379 AN to 1K0 907 379 BJ? Have tried to use same coding and adding zeros to no avail...
    "out of range"
  13. #43
    morfej's Avatar
    Dec 2008
    Where you have seen info that AN can be updated to BJ ?
    Only I have seen 1K0907379AN with 0109 software update.
  14. #44
    Jul 2016
    Quote Originally Posted by morfej View Post
    Sorry I meant, can I put the BJ in place of the AN. Was worried I couldn't as had trouble getting coding to work. After running the car for a while and leaving it on I got the code to go in. Then found out you need to calibrate the steering position sensor etc to get it to stick...
  15. #45
    Jul 2016
    Quote Originally Posted by 1 6 D View Post
    It's not complete coding, there is no start/stop info, size of brakes, no engine type, steering wheel is on which side?
    Here is for steering on left side:
    323B401609260EFB4C1102E4901C7051350000
    Dear 1 6 D, i have a 2009 golf 6 highline 1,4 caxa motronic left side drive. The car gives the "abs code code control unit" not coded or configuration not found error on my mechanics delphi software. When we enter cod control unit for set, we saw 8 pieces double digit, 16 (i think hexadecimal or somethink) value. I cant find the code like this anywhere. Can you help me with that? If you can calculate long code for me, which informations do you need and which hardware and software should ı use?
