Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Hybrid View
    Feb 2013
    Default Openbox V8s Webtv m3u
    Any one point me if i can update webtv m3u files and how . thanks
    Jul 2009
    I am having the same challenge, not sure if V8s takes m3u files and where to find the files. You can update by USB in web tv I guess.
    Any help woulf be great. thanks
    Feb 2014
    there is a rar file in downloads which i uploaded.
    http://www.digital-kaos.co.uk/forums...o=file&id=3165
  4. The Following 5 Users Say Thank You to hfxlad For This Useful Post:
    bys561999 (2nd February, 2015), martin035 (14th March, 2015), nelia (30th October, 2015), skyfatman (27th January, 2015)
    Dec 2013
    soz to b pain when i update with usb it said webtv.m3u failed any helps pls.Thanks
  6. #5
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Quote Originally Posted by tims2k1888 View Post
    You need unrar the files that hfxlad has provided in post #3 then place the files on the root of the USB drive ie not in any folders.
  7. #6
    Dec 2013
    done that but still says the same.could it b the firmware on my box or anything els?
  8. #7
    Feb 2014
    tims2k1888
    this rar file is how to edit your webtv unrar the HOW TO EDIT WEBTV and it will explain everything for you ther is 2 files in the download.
  9. #8
    May 2009
    Hello.
    I know how to edit and create m3u files.
    I read the files provided by hfxlad.
    The problem is the same.
    When I try to read m3u file from dongle Open box V8s say it failed.
    Anyone with any ideas? I try to goggle this problem, lots of people complaint but no one really give a solution.
  10. #9
    Feb 2014
    when you say dongle? do you mean usb?
  11. #10
    May 2009
    Quote Originally Posted by hfxlad View Post
    Yes.
    Copy file from PC to "usb stick" and try to update from there.
  12. #11
    Feb 2014
    does the box recognise the usb when you plug it in?
  13. #12
    May 2009
    Yes. I am using the usb in the front (box say A). Is any difference between them?
  14. #13
    Feb 2014
    try useing the back 1
    and also try formating the usb aswell
    and if you can try another usb.
  15. #14
    May 2009
    Thanks. i will try that and post if it work.
  16. #15
    May 2009
    It was the name of the file.
    Name needs to be : WebTv
    You write your own file, name it WebTv and thats it.
    On PC you will have : WebTv.m3u
    Thanks for your help hfxlad!
