Openbox V8s Webtv m3u
Results 1 to 15 of 22
    Feb 2013
    Default Openbox V8s Webtv m3u
    Any one point me if i can update webtv m3u files and how . thanks
    I am having the same challenge, not sure if V8s takes m3u files and where to find the files. You can update by USB in web tv I guess.
    Any help woulf be great. thanks
    Feb 2014
    there is a rar file in downloads which i uploaded.
    http://www.digital-kaos.co.uk/forums...o=file&id=3165
  4. The Following 5 Users Say Thank You to hfxlad For This Useful Post:
    bys561999 (2nd February, 2015), martin035 (14th March, 2015), mcask (3rd February, 2015), nelia (30th October, 2015), skyfatman (27th January, 2015)
    Dec 2013
    soz to b pain when i update with usb it said webtv.m3u failed any helps pls.Thanks
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Quote Originally Posted by tims2k1888 View Post
    You need unrar the files that hfxlad has provided in post #3 then place the files on the root of the USB drive ie not in any folders.
    Dec 2013
    done that but still says the same.could it b the firmware on my box or anything els?
    Feb 2014
    tims2k1888
    this rar file is how to edit your webtv unrar the HOW TO EDIT WEBTV and it will explain everything for you ther is 2 files in the download.
    May 2009
    Hello.
    I know how to edit and create m3u files.
    I read the files provided by hfxlad.
    The problem is the same.
    When I try to read m3u file from dongle Open box V8s say it failed.
    Anyone with any ideas? I try to goggle this problem, lots of people complaint but no one really give a solution.
  10. #9
    Feb 2014
    when you say dongle? do you mean usb?
  11. #10
    May 2009
    Quote Originally Posted by hfxlad View Post
    Yes.
    Copy file from PC to "usb stick" and try to update from there.
  12. #11
    Feb 2014
    does the box recognise the usb when you plug it in?
  13. #12
    May 2009
    Yes. I am using the usb in the front (box say A). Is any difference between them?
  14. #13
    Feb 2014
    try useing the back 1
    and also try formating the usb aswell
    and if you can try another usb.
  15. #14
    May 2009
    Thanks. i will try that and post if it work.
  16. #15
    Feb 2014
    ok good luck with it
