Page 1 of 2 12 LastLast
Results 1 to 15 of 25
Hybrid View
    Jan 2010
    Default Technomate TM-5402 HD M3 MK3 Super+ CI
    hi guys. Im looking for a replacement to upgrade my f5s and came across this box. The technical bits mash my head so I was wondering if you good people with more knowledge than me could dumb this down for me and tell me if its any good. Im looking to be able to watch 1 channel and record another with a good epg.
    Thanks in advance for your comments
    Member digger99's Avatar
    Dec 2011
    Well the only way you're going to be able to watch one channel and record another using this receiver is if both channels share the same frequency, the TM 5402 only has a single tuner. Besides that it's a decent reciever, although some same that the picture quality is better on the M1 & M2 version which are no longer available.
    Sent from my iPad using Tapatalk
  3. The Following User Says Thank You to digger99 For This Useful Post:
    jc69817 (24th January, 2015)
    Jan 2010
    Thanks for that. Somewhere in the write up it says you can re off 2 and watch another but like you say there is only - tuner. That's what confused me.
  5. The Following User Says Thank You to jc69817 For This Useful Post:
    digger99 (24th January, 2015)
  6. #4
    digicon's Avatar
    Jul 2009
    It can be a little misleading i will try and explain with the following attachment:
    All those Channels are on the same transponder database so the TM marketing blurb says something like Record 2 channels while watching a 3rd on the same transponder, So on that transponder you could record say Tru TV and More Movies while you watch Travel channel exciting i know but thats the general idea one transponder holds an X amount of channels so you can record 2 and watch a 3rd from any single transponder.
    Dont get me wrong the TM5402HD is a great box i have one myself but for the price of a single tuner satellite receiver these days you could pick up say a Vu Zero Linux Enigma2 receiver which will do far more than the technomate can do in a month of sundays, there are also TM E2 receivers the same as the Zero same price as well.
    I think the 5402M3 is around ?119 and the Vu Zero is ?99 and the TM-Nano SE which is identical is also ?99, Also look at other brands at a similar price. Coming from an F5 the next logical step would be a Linux E2 receiver ideally
  7. The Following 3 Users Say Thank You to digicon For This Useful Post:
    digger99 (25th January, 2015), jc69817 (25th January, 2015), mdt (9th March, 2015)
  8. #5
    Member ferretuk's Avatar
    Nov 2008
    Got a tm5402hd m3 new out the box running original tm5402 hd m3 fw. I am after accessing the hidden menu on this box says menu>type 8281 then password no menu opens in system setup tried 8280 goto system info 2 x new menus
    do I have to get phantom patch to access cline menu
    anyone can help I would be grateful
  9. #6
    Oct 2011
    Hi Yes you will need latest Phantom patch and softcam for the goodies... Regards
  10. #7
    Nov 2008
    Thanks for the info just thought there was a hidden menu in the OFW Phantom it is
  11. #8
    Nov 2008
    TM5402HD M3 WILL IT RUN THE M1 M2 FW Thanks Nutsandbolts
  12. #9
    digicon's Avatar
    Jul 2009
    Quote Originally Posted by ferretuk View Post
    No! the 5402HD M3 has its own specific firmware
  13. #10
    Nov 2008
    Digicon thanks could you point me in the direction to where this phantom firmware is as I have looked in the downloads and cannot find it
  14. #11
    digicon's Avatar
    Jul 2009
    Just uploaded it for you: http://www.digital-kaos.co.uk/forums...o=file&id=3198
  15. The Following 2 Users Say Thank You to digicon For This Useful Post:
    jonesy789 (19th April, 2015), mdt (9th March, 2015)
  16. #12
    Nov 2008
    Thank You very much indeed Digicon
  17. The Following User Says Thank You to ferretuk For This Useful Post:
    digicon (10th March, 2015)
  18. #13
    Nov 2008
    Digicon on OFW for the TM5402HD is there a hidden menu for cline or am I right in presuming which is the mother of all FU that to get the hidden menu for cline that the phantom patch must be install also the way to access hidden menu in TM5402HD ive read all sorts 6666 8080 8081 none worked on the STB's OFW. any chance you may know and thanks again for your help us northern monkeys are hanging on the same tree
  19. #14
    digicon's Avatar
    Jul 2009
    We cannot talk about the Cline's or any type of discusssion due to forum rules all i will say is you must have the phantom patch installed to get into the Biss key and Softcam menu:
    Type 8280 into remote control and this will give you the Biss key Menu
    Type 8281 into the remote control and this will give you the Softcam menu which is the part we do not discuss.
    Both of the above will only work with the phantom patch installed
  20. The Following User Says Thank You to digicon For This Useful Post:
  21. #15
    Nov 2008
    Thank You again digicon you have been outstanding with your help and knowledge and it is appreciated
  22. The Following User Says Thank You to ferretuk For This Useful Post:
