Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
  1. #16
    Member ferretuk's Avatar
    Nov 2008
    Hi digicon back on the tm is there a newer phantom patch for this box thanks as i know your awesome with this sat stuff
  2. #17
    Dec 2009
    kidderminster
    The last patch for the said receiver is 146 dtd Aug 16.
    You should be able to see the line when you scroll down the page to posts dated AUG.
    Hope this helps
    DEN
  3. #18
    digicon's Avatar
    Jul 2009
    Quote Originally Posted by ferretuk View Post
    As Above last Phantom Patch for the M3 was August uploaded here: Technomate 5402HD M3
  4. #19
    Nov 2008
    cheers digicon and den1 you guys are awesome. Its the addon im after for the sealion game as the two secret menus cas and biss arent what i thought they were.
  5. #20
    digicon's Avatar
    Jul 2009
    You dont need the 'ADDON' for the M3 version of the 5402 its already built into the Patch, just enter 8281 into the remote will give you what your looking for
  6. #21
    Jan 2017
    Leipzig near Colditz
    Hi, I am back again. I believe this is now the right forum for my queries.
    Further to my achievements: I am beginning to understand my TM 5402 HD M3 CI super + much better from day to day. But an enormous amount of patience is needed. Since I cannot see a signal on my receiver, I'm not sure whether my dish is pointing at the correct satellite. Would the signal show when the channels haven't cleared? First the good news : I managed to patch and install the codes via usb stick. Otherwise the codes 8280 and 8281 wouldn't work. However, I'm not certain to have the dish in the correct position because after following the instructions the ITV and BBC channels still didn't clear. On my receiver the bar at the top should go from red to blue and orange showing that I have contact with the correct Satellite. Ths has never happened. However I got other signals e.g. eurobird9 at 9e, 4.8e sirius 2/3, Bornum1 at 56E, 31e optus. This I did to find out whether my dish is pointing correctly, but i am more confused that ever now. I suppose I must now do a new rest to cancel everything and start again.
    Another question: if I can access the CAS and BISS codes, is it necessary to insert all the apid codes and TV names via keyboard manually?
    Regards
  7. #22
    Dec 2009
    kidderminster
    HI
    When you are locked onto your satellite, the bar at the top should be orange / blue, the transponder for the said channels just to confirm is 11495V 44100.
    You should then be able to scan in the said channels. Go to each channel in turn and action the BISS KEY. The HD channels take a bit longer to sort out.
    THE FOLLOWING INF I HAVE FROM ANOTHER FORUM.
    1 GO TO MENU
    2 GO TO EDIT CHANNELS
    3 GO ADD CHANNELS
    PUT IN 11495V 44100
    ADD CHANNEL NAME (BBC 1 HD )
    VPID 7501
    APID 7502
    PPID 7501
    VIDEO H264
    AUDIO MPEG4
    PRESS YELLOW ON REMOTE (SAVE)
    EXIT
    THEN GO TO CHANNEL - PRESS 8280 ON REMOTE,
    SELECT THE LINE THAT YOU REQUIRE TO USE FOR THE CHANNELS ON 27.5W
    PUT IN THE CODE, EXIT , SAVE.
    After all that the channel should clear.
    Hope this helps
    DEN
  8. #23
    Jan 2017
    Thanks den. I'm on my way to success. Thanks for help.
  9. #24
    Nov 2008
    Just noticed the F4 iptv function with this stb is there a specific format this box uses m3u m3u8 also is it any good for this purpose will iptv subscription work on this box
    Thanks all
  10. #25
    Jan 2014
    Italy
    Not used iptv myself but m3u files can be found free or at cost on the net and downloaded to the box as the patches or softcams are.
