vu+duo 2
Results 1 to 5 of 5
Thread: vu+duo 2
    Apr 2008
    Default vu+duo 2
    hi there, ive been looking at this box for a few weeks now and looked around the forum but cant find much information on recievers with 1 x sat tuner and 1 x cable tuner.
    all in all it looks quite impressive, but can the same image switch between tuners without having to reboot the box?
    ive noticed there isn't a forum thread in the cable section for this box...is it supported?
    any help appreciated.....
    V.I.P. Member benny/9's Avatar
    Nov 2008
    north west uk
    as far as i know you only get a twin sat tuner fitted
    then you can add tuners as required, this box is very
    impressive,i have read elsewhere it works first class
    with a cable and sat tuners fitted, other than this i dont
    know much about the cable side
    Please Read Carefully!
    No Sky UK NDS Videoguard Hacking Discussions.
    Viewing Pay TV without a valid subscription is illegal
    the files available are kept for experimental & educational purpose only
    original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish,
    V.I.P. Member mdt's Avatar
    Feb 2009
    bolton, north-west. uk
    Quote Originally Posted by terminator2k2 View Post
    just a case of adding a additional cable tuner and cables.xml ect and it should work fine. once you have the bouquets sorted you wont know the difference between sat or cable. regards mdt
    DM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30W
    digicon's Avatar
    I dont own the Vu Duo2 at the time far too expensive and not enough tuner configuration combinations, i do own a Giagblue Quad+ running OpenATV 4.3 and it runs fine with both satellite and Cable side no need to add a cables.xml in the openatv image it is already included you just setup autobouquets for either your fixed satellite and Cable netid and your up and running
  5. The Following User Says Thank You to digicon For This Useful Post:
    maca (27th January, 2015)
    Dec 2013
    Yes the Box can Switch the Tuner to Cabel or Sat Signal.
    No Reboot need
