is it posible to log data (when unlooking unit) for renew same unit again later? with out need to buy new token?
Or ist it a different hash then?
-------------------------------------------If my Post is/was helping you... Please press THANX or give REPUTATION
THANX
I am sorry for my bad english
vatomis (16th February, 2015)
I Try to explain You. To unlock ECU , You need readout "sonder hash" (special hash),
and then You need calculate unlock hash and send it to ECU. If this hash is correct and data structure in ECU in normal state - ECU will be unlocked (or renewed).
Next step - You personalise ECU with different data, from another car, and this dataset have different sonderhash than previously stored in ECU, and to unblock (renew) ECU You need calculate unlock hash for actual sonderhash.
But the way to safe Your money - after personalisation not activate ECU before You check them functionality on the car. In This case ECU remain unblocked and re-personalisation is possible.
Regards,
Ne0
anyone knows if it works with 722.8 CVT Ecu for renew, or do you know any tool that can do that?
vevepatronu (26th February, 2015)
possible with dev.
derdud (16th February, 2015), vatomis (21st February, 2015), vevepatronu (26th February, 2015), wsc (16th February, 2015)
Can this tool renew MB EZS (204-176-212) ?
thank you mates
This tool should work on anything with that uses Hashes for drive authorization. Its just the connections that you need to work out as it works via CAN and K line..
has anyone actually bought this tool and used it? Can you virginize basically any computer and install it in another vehicle and do scn coding?
Hi satellitedream i have this tool. All works perfectly.
New firmware
http://sonderhash.com/downloads.php
I have been waiting for 2 weeks now after I paid my money through paypal and still no machine
Love this forum
Better to write to skype "Sonder Hash" , there soon solves the problem.
daniersms (8th April, 2015)
Mate pasquale
It canot do ezs.
Just for ecu ism trans modul..
Regrd
