No mate .. its always been updated/activated every 30 shifts .. nothing new in that .. unless you have the clone that is ..
TM100 support to copy ID44, program or add one new key for VW Sharan 2003 with ID44 ?
If yes, what are the steps ?
Thanks.
Just add a key diagnostic
Hi Guys, just update and get problem at the end "TM100 IO error" "Firmware update failed. Please contact with technical support"
Anybody encountered this problem? Tried to contact Techical Support but no reply yet.
Any suggestion would be appreciated.
ok stall this version on your pc and try version 3.54 i also have same problem after install new version problem solve
https://mega.nz/#!XMQhwZiT!KWEw7Wwm6...j5IYt3Wd50ey4c
To TM100 support Team
Brilliance 2013 ,Immo Eprom 93c56A, transponder PCF7936.
TM100 saying ADD key not tested.
So , I tested today with no success
First key not work
Third key not work
Fault is , Key not registered in ECU Memory.
Colleague, do the work with the siemens 93c56MUESTRA.jpg.
This immobox is used by several Chinese cars
I leave a link so you know more about it. http://www.chlsxs.net/liebaocs6.html
Greetings from Chile
Sorry for bad english.
lion0304 (10th September, 2017), m-o-y (2nd May, 2017), whiskeyman (2nd May, 2017)
Many thanks for replying and code.
a question.
IS there any configuration for it is Transponder.
There is a probability that the chips that did not work in the first programming, have been pre-coded for that immobox, test with x300, skp or other similar.
But first of all, try to program using the module of tm100 siemen 93c56, the same one that sent you the previous screen shot siemens.jpg
I am attentive to your work, tell me the details, greetings
Thank you for your advice, I just done it and still having the same problem: IO error
Fly tech support asks me to ship device back to China for repair
Not quite sure if worth doing it considering shipping cost both way and the repair ....
It's working fine before update ... maybe I should leave it alone rather than update ...
Too late now, so ... decision....decision ....
Mine went back for repair after the same issues.
?30 carriage each way and DHL charging ?27 (cash on delivery) or you don't get your parcel delivered was a bit much to swallow.
But to be fair, the repair was free.
Hi guy... May i no tm100 full version can write toyota master smartkey 2013-2016year...?
Sent from my vivo 1601 using Tapatalk
Has anyone successfully done honda 8e with tm100
Sent from my SM-G361F using Tapatalk
