hi
i tried citroen c1 24c04 not work. i used tango work good
i am no expert, but you are right, the dump is messed up by tm100. some of key data is not added to the dump(eg page 8 and page 2), few checksum errors and invalid S code , hence your car didnt start. it can be fixed by an update but definitely it is tm100 fault and not your page 30 fault
i Suggest fly to give 2 options in their software for their customers, 1st option the old "smart key add to dump" without proximity feature(offline) and 2nd option for those like to add proximity feature into dump( via online if fly is so stubborn)
hi
jnand (27th May, 2017)
Need to push them to improve .....
Siham (30th May, 2017), siyadk (29th May, 2017), whiskeyman (27th May, 2017)
toyota smart keys reset(page 1 :98) doesnt work anymore (ver:6.02)
Have they fixed the writing key into smart box yet for Toyota? Does it work now?
The module is 150 dollars. It is cheeper on tango so I'm not going to buy it and test.
i need help mazda demio immo 68hc05 36AS.ecu 93c56 make key with tm100 car did not start.in tm100 immo 68hC05 34AS is there away to solve this problem
abert mazda demio immo c05.rar
abert mazda demio ecu 93c56 dump.rar
I tried last time
found a difference between ,(TM100 , Tagkey) .and Tango, when write key in ecu.
so I write it in two way.
but also still not receipt a report.
make trasponder with tagno and solve your problem
tm100 is bad tool
bcm2 elv adapt online offline -echange immodata -clone immodata sinchro bcm elv medc17 edc17 Crafter EZS e EDC17 sinchro -DPF/ EGR/ DTC/ removal/: IMMO ADAPT edc16 EDC17 edc17c64 C74 NOW WORKING MED17/MEV17/ VAG ecu clone full working all
PCR2.1 FULL CLONE ou adapt, clone all edc17 me17 , etc / dash echange immodata repair immodata add key etc etc
V6.06 , TOYOTA SMART REMOTE DST80 AND DST 128 RESETS SUCCESSFULLY NOW
