Page 108 of 133 FirstFirst ... 85898103104105106107108109110111112113118 ... LastLast
Results 1,606 to 1,620 of 1981
  1. #1606
    May 2013
    Quote Originally Posted by koyot View Post
    make trasponder with tagno and solve your problem
    tm100 is bad tool
    you lie.now car start it was immo mcu ic not fix well,problem solved.i love my tm100
  2. #1607
    May 2013
    Quote Originally Posted by siyadk View Post
    V6.06 , TOYOTA SMART REMOTE DST80 AND DST 128 RESETS SUCCESSFULLY NOW
    i told you all bug will be fix soon,did you try smart key writing too ?
  3. #1608
    May 2013
    tm100 ver 6.08 is out fix bugs keymaker for toyota smart key system tms37126 today
    TM100 2017-6-6
    V6.08 released
    1. Fix bugs Keymaker for Toyota smart system TMS37126.
  4. #1609
    EARTH
    31. Syncro maker Volvo NEW ??
    Which ecu does it support? tricore eep Give me size error
  5. #1610
    Quote Originally Posted by wphonetei View Post
    you probably love the bugs in it.
  6. #1611
    May 2013
    Quote Originally Posted by jnand View Post
    yes love it better than none and it help me alot
  7. The Following User Says Thank You to wphonetei For This Useful Post:
    lylezim (10th June, 2017)
  8. #1612
    Nov 2015
    i agree tm100 is good
  9. #1613
    siyadk's Avatar
    Dec 2012
    failed on land cruiser smart key 2012 . got an error message saying "fail to data". successfully added key with tango . i dont have dump file with me now, but i will share if i get a chance.
    Version:6.08
  10. #1614
    May 2013
    did you contact fly online engineers on skype ?
  11. #1615
    Jun 2016
    world
    i need help mazda demio immo 68hc05 36AS.ecu 93c56 make key with tm100 car did not start.in tm100 immo 68hC05 34AS is there away to solve this problem
    Attachment 454288
    Attachment 454289
    please if your are not solve your problem post data from key.
    thks.
  12. #1616
    Nov 2014
    mate
    check post #1610
  13. #1617
    Nov 2014
    Hi colleagues, maybe it is the last post of tm100 to do, the work has not gone well and I will have to see other alternatives aside. For me TM100 has been a rewarding tool.
    I hope I have been of help to you.
    Updating Jobs (29-06-2017)
    ? Nissan pathfinder 2007 93c66 (Nat /7)..ok
    ? Nissan Murano 2006 93c56.. ok
    ? Truck Hino 2014 - > immo Toyota Auris 93c66,-> id67..ok
    ? Fiat Fiorino 2007-> immo 0009 brazil, read with orange clone-> ok
    ? Alfa Romeo 147, 2003 -> Maskset: 3K91D programmed with fiat stilo -> read with orange clone ?>ok
    ? Peugeot b?xer 2011-> tp12 ok
    ? Peugeot b?xer 2008-> id48 ok
    ----- image generator ---
    ? opel 40 ok
    ? Chery 40 ok
    ? Mitsubishi 46 ok
    It has not worked (29-06-2017)
    ? Grand Cherokee 2006 (HC912) tp12
    Updating Jobs (19-02-2017) Vehicles scheduled well.
    ? Fiat palio 2001 bcm delphi v1 93c66 16bit id48
    ? Fiat immo 001.11 pinout orange 5 clone ok id48
    ? Fiat fiorino city 2008 id46 93c86 ok (programmed with fiat grande punto module)
    ? Subaru impresa 2014 24c02 ok (same module subaru xv) (chip ID63 80 bit ford-mazda)
    ? Renault kangoo 1999 93c46 t5 ok
    ? Renault logan 2004 93c66 8bit id46 ok
    ? Renault megane 2002 mc68hc705b32 ID4D ok
    ? Suzuki alto 2010 93c56 id46 ok
    ? Toyota Auris 2011 93c66 ok
    ? Daihatsu Terios 2016 93c66 ID4D ok read with UPA (module terios 2004-)
    It has not worked (19-02-2017)
    ? Renault Clio 2003 93c66 8bit unprogrammed
    New things tested until December 2016
    ? Fiat Siena (came with Magneti Marelli (HC912)) ok pinout orange 5 clone ok ID48
    ? Fiat Grande punto 93c86 ok ID46
    ? Peugeot bipper 93c86 ok (programmed with Fiat Grande punto module) ID46
    ? Subaru XV 2014 ok (chip ID63 80 bit ford-mazda)
    ? Chery IQ 2008 ok chip T5
    ? Mitsubishi lancer 2009 antenna 24c16 ok id46
    ? Toyota Hilux 2014 93c66 ok (chip G original)
    ? Volkswagen bora (2008) and gof IV (2001) dashboard 93c86 ok ID48
    ? Fiat tempra 1998 93c46 ok T5
    ? Mitsubishi ASX 2011 ok (24c16) ID46
    Updating Jobs (17-12-2016) Vehicles scheduled well.
    ? Nissan Tiida 2010-2012 x 6 (all ok)
    ? 2012 Nissan versa ok
    ? Fiat Palio 2006 delphi ok
    ? Delphi Fiat Doblo 2007 ok
    ? Chevrolet Sonic 2012 ok (use module astra j)
    ? Chevrolet Sail (x2) 2012, 2014 ok (use module Chevrolet Aveo 93C56) (works but leaves a bug in the dump)
    ? Mitsubishi L200 2008 and 2013 ok (pendrive and ETACS)
    ? Greatwall Haval delphi 2012 immobox ok (eemprom memory is a 6-pin, can be read with orange5 clone, see the image of the prog VVDI pinout)
    ? 2014 Subaru Forester ok (same module subaru XV)
    ? Subaru Tribeca 2008 ok
    ? Toyota corolla 2013, ok (programmed with original key)
    ? Symbol Renault and Nissan Platina (x3) ok (ok remote program control)
    ? Subaru id62 ok
    ? Chery 46 ok
    ? GM 46 ok
    It has not worked
    ? Nissan qashqai 2010 unprogrammed
    ? Nissan xtrail 2007 93c66 unprogrammed
    ? Do not unlock proximity lexus Control
  14. The Following 7 Users Say Thank You to elmelor For This Useful Post:
    Aliazadar (13th March, 2018), Krittanu (30th June, 2017), lion0304 (10th September, 2017), lylezim (29th June, 2017), siyadk (2nd July, 2017), Weasel3 (29th June, 2017), whiskeyman (29th June, 2017)
  15. #1618
    Oct 2015
    USA
    Version 6.08 still not working well with Toyota Smart Key
    I keep getting "Failed to get Data" whenever I try loading a dump.
    If and when it loads I am able to use smart key to lock and unlock door ok,
    but to turn ignition on and start car I "MUST" hold smart key very close to start button.
    Whenever I program in second key via OBD the second keys does the same thing.
    If I use the old version software and add smart key without wireless function and then
    add second key via obd all works ok no problem at all.
    Bottom line is there is no denying that TM100 has some potential but there is still so much
    that needs to be done to make it better.
    Lets see how soons they will take to sort Toyota smart key out.
  16. #1619
    Mar 2011
    Tm100 add key to elantra 2008 flash 29f400 ok.
  17. #1620
    May 2013
    i have s60,80 with all keys lost i use willem lpt programmer read 28f400 flash suceeful and use tm100 original, make key ok write flash back to cem and fix back to car only check engine light display i remove cem and fix flash ic well with very hot air but still same problem.
    baba volvo xc90.gen.bin 1.rar
