Page 109 of 133 FirstFirst ... 95999104105106107108109110111112113114119 ... LastLast
Results 1,621 to 1,635 of 1981
  1. #1621
    lidons's Avatar
    Feb 2011
    Vw tuareg 2008+ edc17, pcf7946remote kessy 93c86, ok
    excuse my English, is the best.
  2. #1622
    Nov 2015
    Quote Originally Posted by wphonetei View Post
    i have s60,80 with all keys lost i use willem lpt programmer read 28f400 flash suceeful and use tm100 original, make key ok write flash back to cem and fix back to car only check engine light display i remove cem and fix flash ic well with very hot air but still same problem.
    Attachment 464564
    check maybe cem and ecu have lost sync
  3. #1623
    May 2013
    Quote Originally Posted by lylezim View Post
    thanks mate,even if lost sync cluster light must work but only check engine light three car here with same problem s60,s80
    i do have same thing with xc90 but i will refix flash ic then ok.but those car i have refix flash ic several times i really need help
  4. #1624
    szengen's Avatar
    Jan 2017
    chevrolet epica ok
  5. #1625
    siyadk's Avatar
    Dec 2012
    when will tm100 fix the bug in toyota smart systems. ???"failed to get data" msg bug
  6. #1626
    lidons's Avatar
    Feb 2011
    I ask
    the MOD Yamaha Moric S29190. Works ID4D62 ???
    I can not get the key to work, I do not know if it is due to TM100 error or Motorcycle error.
  7. #1627
    May 2013
    can one of you offer me volvo s80 flat cem tb2f400 flash file and volve s60 flat cem flash file 26f400 thanks in advance
  8. #1628
    May 2013
    i still need your help friends
    can any of you help me with volvo s60 2002yr,s80 2003yr gray and black CEM i need flash file of mt28f400,ab28f400,tb28f400 thanks in advance
  9. #1629
    Jan 2012
    south florida
    use the file found here virgin cem module use Volvo Vida cem reload and fixe the car
  10. #1630
    May 2013
    So no one will help me guys need your help please
  11. #1631
    May 2013
    Quote Originally Posted by sunlocksmith View Post
    can you send me that virgin file thanks
  12. #1632
    EARTH
    Tm100 7.00
    No transponder in coil antenna.
    Detec = Detect = detecting = 8A car model TOYOTA-SK H >2013???? not trans in antenna.
    She's crazy
  13. #1633
    daniersms's Avatar
    South Africa
    Yes something is not right
    Love this forum
  14. #1634
    Oct 2015
    USA
    Is there anyway to use another J2534 adapter on TM100 by editing the Reg. ?
  15. #1635
    autocheck's Avatar
    Feb 2014
    Zimbabwe
    Can Tm100 connect to J2534 pass thru on VVDI2
    Sent from my A718 Xplora Plus using Tapatalk
