Results 1 to 15 of 28
    Top Poster jack44's Avatar
    Jun 2013
    wien austria
    Default Mercedes Vito emulator dump empty
    Hy friends,
    please help me .
    ECUA 000 153 02 79
    hw 33.98 sw 20.99
    ED6016 CR1,7 2,2 4 ZYL BOSCH 5plugs
    0 281 010 231
    06.08.00
    Mercedes vito
    I mounted emulator and when I read with programmer eprom dump 24c02 data is not complete trench.
    please look into it tell a review please.
    maybe you have a backup.
    I must edit In memory 24c04 in the address 1EE to 1F9
    type 2A 4E 00 00 FF FF 00 9C D4 13 56 01.
    but not found.
    thank you
    Jun 2013
    wien austria
    mercedes vito.rar
    please see this
    and replay
    thenks
    i nead wirgin ecu dump (original).
    Your bin to small , eprom 24C04 programator
    Jun 2013
    wien austria
    hy janusz21,
    yes is to small (corrupt), do you have one virgin?
    or write another from another ECU which is CR1?
    you think not read well with programmer?
    i tried 2 times and same bin.
    Jun 2013
    wien austria
    can put another bin in this ECU? in Ecu A 000 153 02 79
    i mount emulator and wsp is out?
    friends you help my
    thenks
    Jun 2013
    wien austria
    hi guys,
    i found an origina file from other.ECU mercedes Vito 2,2
    I can write in 24c02 ?
    but must be modified address 1EE to 1F9
    what you say a work?
    thenks vito_24c04_Virginfile.rar
    you can modify for me ?
    please
    What programmer you read this, not 24c02 , Reads as 24c04
  8. The Following User Says Thank You to janusz21 For This Useful Post:
    jack44 (15th February, 2015)
    Jun 2013
    wien austria
    hy
    janusz21
    thenks
    you are right is 24c04
    mi programmer is TL866CS
    see new bin please .is full now?
    you meny edit this line address 1EE to 1F9
    mercedes vito 24c04.rar
    I read an older post and you have same Ecu A 000 153 02 79
    hw 33.98 sw 20.99
    0 281 010 231
    06.08.00
    Mercedes vito
  10. #9
    TRAY THIS BIN
  11. The Following 2 Users Say Thank You to janusz21 For This Useful Post:
    jack44 (15th February, 2015), satesquio (5th February, 2016)
  12. #10
    Jun 2013
    wien austria
    thenks frend
    how did you find address 1EE to 1F9?
    can you explain
    to know and I.
    i comme with replay
    thenks man
  13. #11
    Birmingham
    ITS A 24C04 - NOT 24C02
    That is your problem
  14. The Following User Says Thank You to MarkPRP For This Useful Post:
  15. #12
    Jun 2013
    wien austria
    thenks frend Mark prp
    see bin mercedes vito 24c04.rar and VITO OK.ra
    ist ok? little help frend
    sugestion
  16. #13
    writ bin ,conect emulator, disconnect immo and tray
  17. The Following User Says Thank You to janusz21 For This Useful Post:
    jack44 (18th February, 2015)
  18. #14
    Jun 2013
    wien austria
    hi frend
    janusz21 ,
    I tested and Car will not start
    I put and starter the direct with one cable not start
    cable from thermik imo. cut white and green can h ......can l
    I took pictures take a look i cand find wrong.
    i believe is bin from 24c04 ECU.
  19. #15
    Jun 2013
    wien austria
    everyone is welcome with tips
    i thanks so much friends
