PSA EDC17C60 - Communication Error
(can transceiver was replaced)
Hi !
How enable Read button on R5F10D ?
It is a warning on DataFlash area...
BR,
Carradio2001.
when you rfad this chip with xprog it automatically deletes code area
It looks that there are less updates this year on their tool... Last year over 20, this year only about 11 so far... (and some not working at all) Things are moving in the wrong direction... It worth it paying for updates in the future? What is your opinion?
carradio2001 (20th October, 2021)
In xtool is problem with this not working update. All tools have only few updates ( Smok OBD too), but here is not working EDC17 bench read, and this is problem. Price of xtool is OK, if will be update work. Big problem is support too. This update not work long time, and nobody answer now or when will be solved. There is added any MCU programmers, but how this real work we donot know too. On any mcu read and clear data and must follow a certain procedure and reading settings, but such information is not written anywhere. I understand to autor about no need answer to stupid asks, but there is not basic informations. Best is youtube video = Xtool/connect to mcu/setup program/read/write .... 1 minute.
Who is kind enough to open A7 adapter, I found pinout on the website with black wire should be on 25 position on connector, mine was on 14... after moving it to position 25 it sort of killed communication with ca JC cluster that I recovered by flashing it. Thanks... waiting forward to a photo
This is actually, the second adapter that has been modified... A5 also had Yellow and Brown inverted... worse then chinese clones
rtbdiagnostic (10th November, 2021), teerak2uk (10th November, 2021)
2021 Hyundai Tuscon, LCD dash, anyone have any success in correcting one of these, I have read it with option Tuscon 2015..... but it does not read the same as the dash, any pointers or is it completely different to older models, Thanks guys
carradio2001 (26th November, 2021)
