the video is not sharp.
try with the eeprom cable? see if it works. then you know if problem is this reader or xtool it self
I have some problems with the xtool programmer... i can not read any chip.
With other programmer can read the same chip without any problem.
Somebody know's what this is ? or how to solve this problem ?
https://www.youtube.com/watch?v=tYkGPA6OcSI
Try to untick pin check
There is no problem to read with A2 adapter, i read and write without problem.
I tried everything with adapter a1, adapter a2, to untick pin check,i chek the adapter wire connections etc.. i think the problem is the xtool self. I got the programmer like 2 weeks now, other fucntions work well but only
the eeprom programmer dont work, i tried diffrent type eeproms but also not work.
I think must send back for repair.
This is buy the way better sharp video
https://youtu.be/EiImYSGE58E
When you use the
THANKS and REP Buttons
it gives energy to help more
Appreciation is the key
Wrong thread m8.
X-Tool v10.66
EDC17 TC1793 - repair CRC in Eeprom (calculator)
It's mentioned there... repair CRC in EDC17
Renault Master 2015 OBD - will read ori Km, will read Eeprom and save by OBD then will write the new KM, will say writing OK, but will not change. You have to read eeprom and edit manually....
reconct cluster fuse
