ent?o voce diz x tool pisca ta?o filtra dados bs e tra?o fica a funcionar bem no computador debordo e contagem de quilometros?
So you say x tool blinks tails filter data bs and dash stays fine in the onboard computer and kilometer count?
excuse in english
Has everybody on here got the original x-tool (official) from their website?
http://www.x-tool.org/
Or is thread about a clone version?
Cheers
Please hit thanks if this helped you!
There is no clone. Original only.
Ok cheers for that
Hello, I have consulted several users including X-tool.org but I do not have many answers to my doubt regarding X-Tool and BSI's for OBDII, try with partner, 206, 208, 408, C4 and I could not get connection in any Case, "comunication error" is always the message, do you know why it can be? Thank you for your contributions.
206 eeprom 95160 no obd, only eeprom, 208, c4, done bsi by obd,
Cem Volvo C30 conection?
9s12 256
1l1y
Enviado desde mi iPhone utilizando Tapatalk Pro
Galleto V54// carprog v4.7 dongle// Diagbox//vass 5054// x- prog-v50 dongle//rosfar r260- fiat scanner/ svdi vag-bmw-/ fvdi full// digiprog 3// digimaster 2// Renault can clip// vag com // bmw inpa// pasoft 1.4// autocom // Tecnomotor // bmw carsoft 6.5// mercedes carsoft 7.4 // Opel com //
Hi, here I am with a problem equal to the one I had a while ago regarding a VW Brazil combo instrument, the other time I could solve it, with your help, programming first by ODII and then NEC soldering wires. Now the problem is that this Combined board does not recognize communication by OBDII in G6 NEC + 95320, only changes the Km by Gol G5 24c16 but when cutting the current the originals return, what happens, has the data on another side besides the board? I appreciate your help.
please schematic adapter a4 - car radio rns 510 !!!
hi all i sell one full xtool NEW version full adapters and update 2017 year + certyficate .
its ori software and hardware .
remmeber one art.
info skype .
m_yura
-please register forum xtool and ask admin meyby give you diagram adapter A4
mr salamandra
9s12 256
1l1y
mcu9s12dg256 security remmeber! read xprog m
go hands multi and check punct connect mcu easy only 4art connect
mcu pin 23 ist BKGD
40 VSS
41 VDD
42 RESET
I GREET pstryk74
