carprog can read astra h pincode?
Results 1 to 11 of 11
    here there
    Default carprog can read astra h pincode?
    Does anyone knows if carprov clone can read astra h pincode. I succesfulg read pincode on older opel like vectra,astrag, zafira a, on kline but when tryied reading astrah h ecu on can gives error. Maybe i need to modify a1 cable in order to work on can?
    Which engine & ECM ?
    here there
    I tried to read on z16xep, and z16xer no luck, i will try again on 1.7 cdti on monday
    ruffles1986's Avatar
    Sep 2011
    In the Garage
    i read it on Z20LER ME 7.6.2, if your carprog is clone need modify A1 Adapter to read Opel Can
    here there
    @ruffles 1896 can you please tell me how to modify the A1 cable for can?
    Sep 2011
    In the Garage
    Quote Originally Posted by catala20032004 View Post
    Check your A1 Adapter, this solution should work for Opel Can
  7. The Following 11 Users Say Thank You to ruffles1986 For This Useful Post:
    amerocanada (9th September, 2018), antwnhszr (19th April, 2015), catala20032004 (25th February, 2015), chcp (9th September, 2018), instakeys (24th February, 2015), Jashmine1983 (1st June, 2015), joze (9th April, 2015), k1champion (28th June, 2015), MAYQUAD (1st September, 2015), sasa5 (4th October, 2015), stanislav georgiev (13th March, 2015)
    Mayby external power dont conect?
    Home
    Hi i have genuine carprog and he can't read correct pin from opel edc16 ecu.
    He will read pin but is incorrect.
  10. #9
    igorr's Avatar
    Aug 2010
    clone will read pin from astra H edc16 tested many times
  11. The Following User Says Thank You to igorr For This Useful Post:
    taxo1965 (27th February, 2018)
  12. #10
    What about EDC16c39 ???
  13. #11
    Sep 2018
    Warsaw
    Quote Originally Posted by drahe View Post
    I just read and write successfully with carprog 10.05 reworked
