Page 14 of 14 FirstFirst ... 491011121314
Results 196 to 209 of 209
  1. #196
    melbourne, australia
    I just got mine today.........installing it as we speak
    = ABRITES Diagnostics for Mercedes/Smart/Maybach 9.2
    - !!! HIT !!! Password extraction for the following models in all keys lost
    situations: W169, W176, W202, W208, W210, W164 (nec), W221 (nec), W216,
    W463, X164 (nec), W251 (nec)
    - !!! HIT !!! Support for a new adapter (with fuse relay) that allows for
    quick password extraction (for example for W2014, W211 and others where
    password extraction time is decreased by 10 times!)
    - Added new versions for password extraction for W946 for example
    - New functionality to the DAS Manager introduced which allows operation
    with IR-keys
    - Ability for programming of used keys (BGA) with known password
    - Additional ease of usage of ABProg together with DAS Manager
    - New versions added for dump recognition W220, W946, etc.
  2. #197
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    In my immobox...
    I got 9.3 Today
  3. The Following User Says Thank You to lupu_sandu For This Useful Post:
    joemajdalani (17th August, 2016)
  4. #198
    Aug 2016
    anyone here has the updated mn026? trying to revive this thread. Feedback. thanks
  5. #199
    Mar 2017
    Quote Originally Posted by markclay View Post
    Junk. Vvdi mb does a much better job.
  6. #200
    Dec 2012
    EU
    Quote Originally Posted by ps80l View Post
    In witch is vvdi is better?
    And why avdi is junk?
    Sent from my SM-G935F using Tapatalk
    Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
  7. The Following User Says Thank You to gttuning For This Useful Post:
    joemajdalani (17th April, 2018)
  8. #201
    Mar 2017
    Quote Originally Posted by gttuning View Post
    All add key jobs I do vvdi average 15 to 20 minutes. Avdi same cars fastest ever 25 minutes...Many 2.5 hours...and some fail. This is tested on the same cars!!!
    Two days ago S series 2011... car had BE key. Avdi could not read BE password. vvdi2 about 10 seconds. I then proceeded to test normal password read. Avdi failed at about three hours. Avdi done in 15 minutes.
    Also I have tested several cars with fuse relay method. All have fail to get pass after several hours.
  9. #202
    Gavra's Avatar
    Belgrade/Melbourne
    Your PC is probably old junk......AKL on many cars is under 20 min...spare key no more than 10.........
    Guided fault finding = Feature that many factory scan-tools have and real technician despise it.
  10. #203
    Ive found AVDI to be pretty good on merc cars, the only times it really has issues is when I need to learn to use it better
  11. #204
    Mar 2017
    Quote Originally Posted by Gavra View Post
    Please share your specs... So you are saying that avdi is junk code and requires a super computer? All other software from other companies runs smooth on the Intel i5 2.6ghz with 8gb ram and SSD
  12. #205
    Gavra's Avatar
    Belgrade/Melbourne
    No, I am saying you are not realistic. I use it daily and besides occasional server errors it's working flawless on MB FBS systems...... And I use it on W164 mostly......which is hardest to do.....
  13. The Following User Says Thank You to Gavra For This Useful Post:
    shafo (20th April, 2018)
  14. #206
    Mar 2017
    Your argument is that my pc is junk... Now your saying it's not? Share your specs. My results have been horrible. So horrible that avdi even thought my distribution box was bad. They checked their logs and even sent me a new unit. Problem didn't go away and now they ignore me. I've even tried three different computers and all same problem.
  15. #207
    Mar 2017
    Gavra...still waiting for your computer specs.... VVDI MB needs internet only to send then data read from car and to generate keys. About 3 seconds of internet to send them data. You then request password...another 3 to 5 seconds of internet. Prepare keys about 20 seconds of inter. So about 30 seconds total...
    Why is it that junk code avdi needs internet at all times and if it's not fast enough it slows down procedure(supposedly). ???
  16. #208
    Gavra's Avatar
    Belgrade/Melbourne
    Mate, sell avdi and use vvdi.....go on their forum and write how good it is.......here on DK people use wide range off tools and share experience about it....just because you don't like avdi and have issues with it does not mean code is bad....and I am using CF20 and T5580.......
  17. The Following User Says Thank You to Gavra For This Useful Post:
    joemajdalani (25th April, 2018)
  18. #209
    doctore's Avatar
    Nov 2015
    Colorado Denver
    better sell both tools
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
