JFR-Tuning (16th August, 2019)
super
but is it not SIP22 profil ?
How i can extract the code from the stamp by GT15?
Hello, my friend
Your key profile is gt15, and is found in older models of Fiat vehicles.
Newer models have the sip22 ,
key Cutting codes of both old and new are usually stamp, on the switch and on Airbag passenger ,
I hope I understood your questions and answered them correctly
first thnx
yes shure what you answer I know I asking this because my new Dolphin xhorse get a SIP22 key for this car.
thats wrong
but one question I have
how or can I translate the stamp code on the Airbag Switch to a Code in instacode ? To get the bitting
i know for SIP22 you must take the last numbers and DE BEFORE
bur it how it works for GT15 ?
very easy. insert blank key in lock and see variations. there are 3 depth. depths number 1 are not cut.
6841707059 576F526B 57416E5453 596F55 526F6B69424152
alclot (29th August, 2019), JFR-Tuning (17th August, 2019)
Sorry I don‘ t understand newbie
for exeble in in my case
look stamp on picture before
the last 4 digids are 9120;
the key4man translate it in W009120
my my question is :
how can I know that I must use for the GT15 key w00xxxx
i need the Manuel in instacode or other way to know how I can complete the last 4 digits of a stamp on a lock
W = GT15
DE = SIP22
That's all what you need
W series = GT15
DE series = SIP22
That's all what you need.
ExpressSSD (6th June, 2021), JFR-Tuning (18th August, 2019)
thnx
yes it is but in each case I want to know witch is the full code and where I get the letters and numbers to complete the stamp code on Airbag switch or in other manufactures.
But i found the Problem
Solved,
the Problem was in Datasheet from xhorse Dolphin. There it is written SIP22 for a punto 2004. this is wrong . Use only instacode then you find the full numbers and fill the front letters and the the Full numbers from it. You need advance in instacode
Here in picture in adavance you can see the full code ( 1)
but where I get the isn number (2)
Hey. How to determine the mechanical key code Hummer H3 ?
AIHAM (18th February, 2021)
How to determine beating code from door lock stamp in Peugeot Partner 2011 ? please help
