Page 8 of 14 FirstFirst ... 345678910111213 ... LastLast
Results 106 to 120 of 197
  1. #106
    DK Veteran labusas's Avatar
    Nov 2010
    Hi. Please advice on finding key code on Chevy suburban 2012. Thanks
  2. #107
    Jun 2018
    Thank you very much. Far too kind
  3. #108
    camelgd's Avatar
    Jan 2011
    South Illinois
    Ignition plug only, must be removed to be seen, for 2012 Suburban.
  4. #109
    Jul 2018
    What if the customer don't want the door lock to be removed??
    Is there all in VIN to keycode calculating software that covers all types of vehicle?
    I also hear some locksmiths they have access to some vendor database ( toyota for instance) to get keycodes, Is that true?
    Thanks for your response, very helpfull all
  5. #110
    camelgd's Avatar
    Jan 2011
    South Illinois
    Let Mr Li be your friend...
  6. #111
    Aug 2018
    USA
    2012 malibu key code locations, i try with lishi GM37 but the door lock I think it's broken i can turn it to unlock with only picking number 4
  7. #112
    Aug 2018
    USA
    2012 US Toyota camry, keycode in driver door lock .
  8. #113
    Jan 2017
    USA ����
    Quote Originally Posted by hai82der View Post
    On ignition remove and read
  9. The Following 2 Users Say Thank You to sleepyrz For This Useful Post:
    hai82der (24th February, 2019), rudoni (21st June, 2022)
  10. #114
    Jun 2017
    US
    Had a couple GM door locks that picked on the first or second bound wafer. Still decoded fine though.
  11. The Following User Says Thank You to darknezz19 For This Useful Post:
  12. #115
    Aug 2018
    USA
    I will try to remove the ignition today i hope its not hard to do it. all wafer decode give me number 1 ? and 4 its 3
  13. #116
    super jumbe's Avatar
    Livingstone
    Quote Originally Posted by Friends4eva View Post
    Send him to steeler...
  14. #117
    Livingstone
    Quote Originally Posted by parapilot View Post
    dont waste your time boys, most of these puntos, open passanger door, you will see an airbag lock. pops out in 5 seconds. All cuts are inside, and number printed on barrel. 2 min job.
    There is no airbag lock on Punto Grande from 2006 onwards and no codes on door locks only on old Punto….
  15. #118
    castin's Avatar
    Oct 2015
    Hi. Mercedes Sprinter 2002 - possible to find key cut code? AKL sit.
  16. #119
    Jan 2017
    USA ����
    get hu100 IRT set of 4
    and the a1 rocker pick set/ tension tools for gm
    and did you cut this key and try it in the door then????????!!!!!!!!!!!?!!?!?!
  17. #120
    Top Poster rojhat's Avatar
    Sep 2015
    france
    hi member have chevrolet captiva all key lost
    for cutting code on barrel or igntion any one have find or give me location maybe
    br
    Envoyé de mon SM-A605FN en utilisant Tapatalk
