Page 1 of 15 12345611 ... LastLast
Results 1 to 15 of 224
    spychu14's Avatar
    May 2011
    POLAND
    Default Need PIN VIN MAC CS from EDC17 VAG dump.
    I need to extract some immo data from 2 dumps EDC17 VAG.
    Need VIN PIN MAC CS - powclass would be usefull too if anyone can.
    IMMO EDC17.zip
    VAG
  2. The Following User Says Thank You to spychu14 For This Useful Post:
    Tomate (23rd October, 2017)
  3. #2
    Apr 2011
    in lebanon
    Hello.
    from vwT5 = PIN 60546. CS: 90 ED 20 67 CD 61. MAC:A1 F6 E9 BD. VIN:WV1ZZZ7HZCH022430
    from golf gtd = pin 55069. CS:B6 43 51 6B 6C 86. MAC:0D 35 31 23. VIN:WVWZZZ1KZAW324745
  4. The Following 10 Users Say Thank You to haroutioun For This Useful Post:
    adygopo (14th February, 2022), antonypaul (1st June, 2015), mossa19 (31st January, 2018), MRAWZIN (22nd February, 2018), PremierD (13th March, 2015), richard27 (22nd February, 2018), spychu14 (4th March, 2015), systemlinux (12th June, 2020), Tomate (23rd October, 2017), Toutancamon (26th October, 2022)
  5. #3
    spychu14's Avatar
    May 2011
    POLAND
    Everything is OK. But one question - how to extract 7th byte of CS without dashboard ?
    What software have you used ?
    VAG
  6. #4
    Apr 2011
    in lebanon
    Quote Originally Posted by spychu14 View Post
    there is 2 kind point to get the 7th bytes (1) from dashboard & (2) from working key.
  7. The Following User Says Thank You to haroutioun For This Useful Post:
  8. #5
    spychu14's Avatar
    May 2011
    POLAND
    What programmer do I need to extract from key ? Car was burnt. Dashboard too
    VAG
  9. #6
    Apr 2011
    in lebanon
    ok,but you load 2 different dumps from which one you need to get the 7th bytes? normally you can use (avdi tag key tool) or tango programer, if your key is ready to give as the 7bytes.
  10. The Following User Says Thank You to haroutioun For This Useful Post:
  11. #7
    spychu14's Avatar
    May 2011
    POLAND
    They are only my test readings. I have complete read from ecu and dashboard to confirm that everything is matching. Didnt have read from burnt car yet. Thanks for help.
    VAG
  12. #8
    Apr 2011
    in lebanon
    OK my friend if any new let us to know we are here just for help,good luck...
  13. The Following 2 Users Say Thank You to haroutioun For This Useful Post:
  14. #9
    Golf 6 and T5.2 uses 12byte unique not 7. Only solution to use old keys is trip to dealer.
  15. #10
    spychu14's Avatar
    May 2011
    POLAND
    OK - so lets start a battle...
    This is dump from sharan to extract immo data.
    sharan edc17c46.rar
    VAG
  16. #11
    Apr 2011
    in lebanon
    Hello.
    CS= 1e 19 87 d3 6c e7 00.
    pin= 08847.
    mac= 5d 30 ba 52.
    vin= WVWZZZ7NZDV000878.
  17. #12
    yugo45's Avatar
    In this case , put new transponder in key,Match Cluster and ECU with 6 byte of original ECU and leave 7 Byte of new cluster. After that Add new key in cluster.
  18. #13
    spychu14's Avatar
    May 2011
    POLAND
    Thanks. One more question. Is powerclass in dashboard important for immo ?
    VAG
  19. #14
    Apr 2011
    in lebanon
    Hi.
    must be the same power class in both for ecu and dash,if not same you can change it manual from in the dash.
  20. #15
    yugo45's Avatar
    If you get same part number Cluster and ECU what that car had it , then you should not have problem with Power class.
